| Tdskip |
Oct 9 2020, 07:33 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
I've heard it both ways (nod to any Psych fans out there), and preferred orientation of the linkage?
Thanks! |
| Gint |
Oct 10 2020, 03:00 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,111 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
A lot of it depends on what other junk is in your engine compartment, whether your accelerator cable is long enough, etc... You're going to have to get your head in there with a linkage and have a look. Whatever works. I remember swapping back and forth trying to figure out the best way to do mine at one point. I searched and looked at pics and saw both in use. CSP bell crank linkage is what I run now and prefer it over the standard cross bar linkage.
Tdskip IDF Weber with hex bar - linkage towards front or rear of car? Oct 9 2020, 07:33 AM
Mark Henry
... preferred orientation of the hex bar linkage?... Oct 9 2020, 07:45 AM
Tdskip
... preferred orientation of the hex bar linkage... Oct 9 2020, 08:11 AM
914werke ... preferred orientation of the hex bar linkage... Oct 9 2020, 09:28 AM
rhodyguy On the front. PITA standing on your head dialing t... Oct 9 2020, 11:32 AM
Spoke I had the bar connected towards the rear but the l... Oct 9 2020, 12:08 PM
Tdskip Thanks for the responses - just need to get this o... Oct 9 2020, 01:14 PM
ndfrigi
Thanks for the responses - just need to get this ... Oct 9 2020, 01:29 PM
Ansbacher I have a hex bar linkage and am confused by this w... Oct 9 2020, 02:25 PM
rhodyguy The forward side of the carbs.
Throw the cross ba... Oct 9 2020, 02:41 PM
Ansbacher I think if I tried to put it in front of my carbs,... Oct 9 2020, 02:55 PM
nditiz1 Towards the front of the car. If you are just try... Oct 10 2020, 11:35 AM
Tdskip Thanks for all of the responses. I just need to ge... Oct 10 2020, 02:17 PM
Ansbacher So...to do a swap from front to back or vice-versa... Oct 10 2020, 06:54 PM
Tdskip
So...to do a swap from front to back or vice-vers... Oct 11 2020, 07:06 AM
Gint Carbs swapped, no. You would have to take the end... Oct 11 2020, 12:35 PM
Tdskip
Carbs swapped, no. You would have to take the en... Oct 11 2020, 12:44 PM
Gint Carbs swapped, no. You would have to take the end... Oct 11 2020, 01:07 PM
Gint Ok, whatever works for you. That would mean your ... Oct 11 2020, 12:50 PM
Tdskip Thanks for all of the responses and discussion, in... Oct 11 2020, 02:42 PM
Gint Info, exchange of information and ideas never hurt... Oct 11 2020, 02:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th September 2026 - 02:39 AM |
