> IDF Weber with hex bar - linkage towards front or rear of car?
Tdskip
post Oct 9 2020, 07:33 AM
I've heard it both ways (nod to any Psych fans out there), and preferred orientation of the linkage?
Thanks!
Ansbacher
post Oct 10 2020, 06:54 PM
So...to do a swap from front to back or vice-versa, does that mean the carbs get switched left to right and mounted backwards from the original installation?? I just can't wrap my head around all this.
Ansbacher
Tdskip   IDF Weber with hex bar - linkage towards front or rear of car?   Oct 9 2020, 07:33 AM
Mark Henry   ... preferred orientation of the hex bar linkage?...   Oct 9 2020, 07:45 AM
Tdskip   ... preferred orientation of the hex bar linkage...   Oct 9 2020, 08:11 AM
914werke   ... preferred orientation of the hex bar linkage...   Oct 9 2020, 09:28 AM
rhodyguy   On the front. PITA standing on your head dialing t...   Oct 9 2020, 11:32 AM
Spoke   I had the bar connected towards the rear but the l...   Oct 9 2020, 12:08 PM
Tdskip   Thanks for the responses - just need to get this o...   Oct 9 2020, 01:14 PM
ndfrigi   Thanks for the responses - just need to get this ...   Oct 9 2020, 01:29 PM
Ansbacher   I have a hex bar linkage and am confused by this w...   Oct 9 2020, 02:25 PM
rhodyguy   The forward side of the carbs. Throw the cross ba...   Oct 9 2020, 02:41 PM
Ansbacher   I think if I tried to put it in front of my carbs,...   Oct 9 2020, 02:55 PM
nditiz1   Towards the front of the car. If you are just try...   Oct 10 2020, 11:35 AM
Tdskip   Thanks for all of the responses. I just need to ge...   Oct 10 2020, 02:17 PM
Gint   A lot of it depends on what other junk is in your ...   Oct 10 2020, 03:00 PM
Ansbacher   So...to do a swap from front to back or vice-versa...   Oct 10 2020, 06:54 PM
Tdskip   So...to do a swap from front to back or vice-vers...   Oct 11 2020, 07:06 AM
Gint   Carbs swapped, no. You would have to take the end...   Oct 11 2020, 12:35 PM
Tdskip   Carbs swapped, no. You would have to take the en...   Oct 11 2020, 12:44 PM
Gint   Carbs swapped, no. You would have to take the end...   Oct 11 2020, 01:07 PM
Gint   Ok, whatever works for you. That would mean your ...   Oct 11 2020, 12:50 PM
Tdskip   Thanks for all of the responses and discussion, in...   Oct 11 2020, 02:42 PM
Gint   Info, exchange of information and ideas never hurt...   Oct 11 2020, 02:50 PM
- Lo-Fi Version Time is now: 15th September 2026 - 02:40 AM
