DANNYMAC |
Member ![]() ![]() Group: Members Posts: 86 Joined: 8-July 20 From: NORTH HOLLYWOOD CALIFORNIA Member No.: 24,470 Region Association: Southern California ![]() |
I have an original 19000 mile car, but the rear deck lid is not correctly aligned, no gap on one side large gap on the other ? Is there anyway to adjust these lids ? Don't believe it's ever been hit or repaired ? Help please
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,860 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
First check and make sure the hinge mounts aren't broken or starting to break. A good sign of trouble is lots of creaking.
Mark the current position of the lid on the rear hinge brackets, so you know where you started. Take the trunk latch off the tail panel, this is so you can put it in the closed position without having to unlatch every time. Barely loosen the decklid mounting bolts so it will hold position yet move with some force. Adjust the position of the lid and tighten it up, replace the latch, and lubricate the pivot shoulder bolts. |
Lo-Fi Version | Time is now: 5th September 2025 - 07:10 AM |
