| brcacti |
Oct 12 2020, 12:49 PM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hi all, I made an appt to take the car in have oil fumes inside car when pull heater knob. The porsche mechanic said probably have oil dripping on the 3-4 foot long heat exchangers and inside for years built up. He said on VWs they usually replace them are they available for 914s. If not available he said he may be able to bring them to a radiator shop and have them cleaned out. I need some guidance, opinions and suggestions on this project.
| Cairo94507 |
Oct 12 2020, 03:36 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,610 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I totally agree with top off driving. I really think it makes the car so much more enjoyable. Of course here in CA it's easy to pull that off. (IMG:style_emoticons/default/beerchug.gif)
| brcacti |
Oct 12 2020, 03:53 PM
I totally agree with top off driving. I really think it makes the car so much more enjoyable. Of course here in CA it's easy to pull that off. (IMG:style_emoticons/default/beerchug.gif) This time of year I can keep it off for one/two months. We have a carport at work I pull under for the 5 hours I am there from 5 am to 10 am. We get very cold mornings in Dec, Jan, feb, march to unless I wear a thick coat will travel with top on. I MIGHT just do the thick coat, will try that. Made an appt to take the car in Nov 2 but will have to drive one hour to get it there (IMG:style_emoticons/default/sad.gif) |
brcacti heat exchanger pipes Oct 12 2020, 12:49 PM
Cairo94507 It is not uncommon for oil to pool in the heat exc... Oct 12 2020, 01:11 PM
brcacti
It is not uncommon for oil to pool in the heat ex... Oct 12 2020, 02:51 PM
bdstone914 He is probably correct. Pull all the heat tin and ... Oct 12 2020, 01:13 PM
bdstone914
He is probably correct. Pull all the heat tin and... Oct 12 2020, 01:16 PM
ndfrigi if no leaks from the header pipes to HE box, just ... Oct 12 2020, 01:13 PM
DANNYMAC
if no leaks from the header pipes to HE box, just... Oct 12 2020, 01:44 PM
bdstone914
if no leaks from the header pipes to HE box, jus... Oct 12 2020, 08:40 PM
ndfrigi
[quote name='ndfrigi' post='2858415' date='Oct 12... Oct 12 2020, 09:39 PM
Gint I used to drive mine to work and back with the top... Oct 12 2020, 07:26 PM
SO.O.C914er Bruce are these 1.7 or 1.8 HE on Craigslist? Looks... Oct 12 2020, 09:56 PM
ndfrigi
Bruce are these 1.7 or 1.8 HE on Craigslist? Look... Oct 12 2020, 10:51 PM
Rikyrat I have a set of 74 1.8 heat exchangers, that have ... Oct 13 2020, 12:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:23 PM |
