Break in Compression 2 Liter, Valve Adjust/Duration/Lift...etc |
newdeal2 |
Dec 20 2004, 05:13 PM
Unregistered |
OK, here's the scoop. I have the car running [the infamous 2 liter D jet re build] reasonably well. I re did the compression test [all plugs out/Throttle open]and it ranges from 120 -140.
I have been told that the WebCam [by Raby] having a longer duration and better lift will throw numbers off since it is intended to improve the mid range. I have also noted from various sources that it could be a simple valve adjustment that will bring the numbers closer. Am I getting too anal here? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
newdeal2 |
Dec 21 2004, 06:29 AM
Unregistered |
Everything was kept stock, only changes as noted [cam and euro pistons] in my earlier reply. Crank and heads as well as align bore was done by a Porsche mechanic locally.
Lo-Fi Version | Time is now: 7th June 2024 - 03:55 AM |
