| burlybryan |
Oct 13 2020, 07:55 PM
Member ![]() ![]() Group: Members Posts: 148 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
My new-to-me car came with the feature of the parking brake chime (turn signal relay) chiming while the car is running even when the brake is off (although the frequency of the chime is different from when the brake is actually activated).
I've replaced the old crusty parking brake switch but that didn't fix it. Tonight, while driving, the light decided to join the chime in blinking. Parking brake is off and the switch is fully depressed. Parking brake chime and light work as normal when the brake is pulled. UPDATE: Pulled the boot and I have a single wire (brown/yellow) on the switch and it's the style that doesn't have a reset button. Wiring schematic for 74 indicates that I should also have a brown ground wire as well. Over the course of my research, it seems that EVERY thread that involves a non-button reset switch dies without reaching a conclusion. Time to replace the switch? Search for a grounded wire? Bryan |
| bdstone914 |
Oct 13 2020, 09:24 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,295 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Check the reset button on the switch on the naster cylinder. There is a small pin in the center. Push it in. If the brakes were bled recently that could be the problem.
| burlybryan |
Oct 14 2020, 09:17 AM
Check the reset button on the switch on the naster cylinder. There is a small pin in the center. Push it in. If the brakes were bled recently that could be the problem. Thanks. I should have mentioned that my MC switch is a single wire with the black plastic fin in the middle. There is no reset button on this MC switch as far as I know. Is there a second wire (like some other switches) that needs to be grounded? |
burlybryan brake warning chime on all the time - misdiagnosed, starting new thread Oct 13 2020, 07:55 PM
burlybryan Update. I pulled the new parking brake switch and ... Oct 14 2020, 07:11 PM
theer My '72 doesn't have a chime. Is that a se... Oct 14 2020, 07:15 PM
burlybryan Yep. Gonna kill this thread and start a new one. ... Oct 14 2020, 07:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 01:09 AM |
