Windshield washer system, Converting |
Morph914 |
Oct 14 2020, 08:05 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I took the steering column apart today to familiarize myself with the windshield washer system. It appears that the PO converted the system to a pump from the the parts I found in one of many boxes of parts that came with the car when I bought it.
I would like to utilize the existing control on the column to operate the washer if possible. After watching Sir Andy’s video, it would appear that I can run a lead off of this black / brown wire that runs to the relay, to the washer pump and then just ground it near or at the pump. And then I’m thinking about mounting the pump in this area, but hoping that someone will chime in to verify that I can do this or any thoughts on a better way |
Ian Stott |
Oct 15 2020, 04:38 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
My teener has that, it is mounted on the other side of the hose which puts it underneath the reservoir out of sight, either spot is fine.
Ian Stott Moncton Canada |
Morph914 |
Oct 15 2020, 05:22 AM
914Toy |
Oct 16 2020, 09:39 AM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
My teener has that, it is mounted on the other side of the hose which puts it underneath the reservoir out of sight, either spot is fine. Ian Stott Moncton Canada Thank you Mount it under your reservoir so that the pump is gravity fed. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:01 PM |
