| BPic |
Oct 17 2020, 01:15 PM
Member ![]() ![]() Group: Members Posts: 350 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues.
The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) |
| porschetub |
Oct 17 2020, 01:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,196 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues. The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) You have the wrong part that holds the nylon ball cup,believe you have the shorter one,I would think all will come good when you change it . Good luck. |
| BPic |
Oct 17 2020, 01:47 PM
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues. The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) You have the wrong part that holds the nylon ball cup,believe you have the shorter one,I would think all will come good when you change it . Good luck. There's more than one size of those cast cups? I have 2 from 2 different transmissions and both the same. I'll start looking now. Thanks. |
BPic Trans question for the brain trust Oct 17 2020, 01:15 PM
porschetub
[quote name='porschetub' post='2859767' date='Oct... Oct 17 2020, 02:34 PM
BPic I measured mine and both are 65 mm. Anyone know wh... Oct 17 2020, 02:13 PM
Rich Bontempi
I measured mine and both are 65 mm. Anyone know w... Oct 17 2020, 02:41 PM
dr914@autoatlanta.com that shift head looks correct, have you installed ... Oct 17 2020, 02:43 PM
BPic
that shift head looks correct, have you installed... Oct 17 2020, 02:48 PM
mepstein Early ones for the tailshifter are shorter than th... Oct 17 2020, 02:28 PM
Rich Bontempi
Early ones for the tailshifter are shorter than t... Oct 17 2020, 02:43 PM
Rich Bontempi
My trans goes into all gears but pops out of 2nd.... Oct 17 2020, 02:39 PM
BPic
My trans goes into all gears but pops out of 2nd... Oct 17 2020, 02:46 PM
Rich Bontempi
[quote name='Rich Bontempi' post='2859781' date='... Oct 17 2020, 02:50 PM
Rich Bontempi
[quote name='Rich Bontempi' post='2859781' date=... Oct 17 2020, 03:34 PM
BPic
[quote name='Rich Bontempi' post='2859790' date='... Oct 17 2020, 03:48 PM
Rich Bontempi
My trans goes into all gears but pops out of 2nd.... Oct 17 2020, 02:48 PM
BPic
My trans goes into all gears but pops out of 2nd... Oct 17 2020, 02:50 PM
ndfrigi Have you tried shifting it to 2nd gear by hand on ... Oct 17 2020, 03:59 PM
rhodyguy Is the pinkish stuff on the ball bushing material ... Oct 17 2020, 06:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th November 2026 - 05:30 PM |
