> Trans question for the brain trust
BPic
post Oct 17 2020, 01:15 PM
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues.
The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif)
I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif)
Rich Bontempi
post Oct 17 2020, 02:39 PM
914 Road Racer
QUOTE(BPic @ Oct 17 2020, 12:15 PM) *
I'm looking at your pic, and I can't see the washer that goes on both sides of the shift housing and the lever. There should be one washer on both sides of the shift housing. We stock them, if they aren't there. Rich
BPic
post Oct 17 2020, 02:46 PM
QUOTE(Rich Bontempi @ Oct 17 2020, 04:39 PM) *
Rich do you mena the highlighted washer? I'll check.
BPic   Trans question for the brain trust   Oct 17 2020, 01:15 PM
porschetub   My trans goes into all gears but pops out of 2nd....   Oct 17 2020, 01:44 PM
BPic   My trans goes into all gears but pops out of 2nd...   Oct 17 2020, 01:47 PM
porschetub   [quote name='porschetub' post='2859767' date='Oct...   Oct 17 2020, 02:34 PM
BPic   I measured mine and both are 65 mm. Anyone know wh...   Oct 17 2020, 02:13 PM
Rich Bontempi   I measured mine and both are 65 mm. Anyone know w...   Oct 17 2020, 02:41 PM
dr914@autoatlanta.com   that shift head looks correct, have you installed ...   Oct 17 2020, 02:43 PM
BPic   that shift head looks correct, have you installed...   Oct 17 2020, 02:48 PM
mepstein   Early ones for the tailshifter are shorter than th...   Oct 17 2020, 02:28 PM
Rich Bontempi   Early ones for the tailshifter are shorter than t...   Oct 17 2020, 02:43 PM
Rich Bontempi   My trans goes into all gears but pops out of 2nd....   Oct 17 2020, 02:39 PM
BPic   My trans goes into all gears but pops out of 2nd...   Oct 17 2020, 02:46 PM
Rich Bontempi   [quote name='Rich Bontempi' post='2859781' date='...   Oct 17 2020, 02:50 PM
Rich Bontempi   [quote name='Rich Bontempi' post='2859781' date=...   Oct 17 2020, 03:34 PM
BPic   [quote name='Rich Bontempi' post='2859790' date='...   Oct 17 2020, 03:48 PM
Rich Bontempi   My trans goes into all gears but pops out of 2nd....   Oct 17 2020, 02:48 PM
BPic   My trans goes into all gears but pops out of 2nd...   Oct 17 2020, 02:50 PM
ndfrigi   Have you tried shifting it to 2nd gear by hand on ...   Oct 17 2020, 03:59 PM
rhodyguy   Is the pinkish stuff on the ball bushing material ...   Oct 17 2020, 06:55 PM
- Lo-Fi Version Time is now: 5th November 2026 - 05:30 PM
