| jim_hoyland |
Oct 18 2020, 04:14 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,167 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
The rubber top fits nicely; but it appears there is an extra stud in the center with no hole to go through. What am I missing here ? Should the stud be capped ?
@Mikey914 Attached thumbnail(s) Attached image(s)
| JeffBowlsby |
Oct 18 2020, 08:40 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,393 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
The license plate lights mounting screws penetrate that steel reinf in the bumper top. One of the two screws for each light is a ground screw. That tab on the 70-74 chassis provides grounding for the lights. If the lights are not hooked up correctly you’ll blow fuses due to a direct short of the lights power circuit to ground.
| jim_hoyland |
Oct 19 2020, 06:22 AM
The license plate lights mounting screws penetrate that steel reinf in the bumper top. One of the two screws for each light is a ground screw. That tab on the 70-74 chassis provides grounding for the lights. If the lights are not hooked up correctly you’ll blow fuses due to a direct short of the lights power circuit to ground. Aha ! My new bumper top has one hole near the end of each license plate nook; however, the new Uro license plate lights mounting holes don't line up with that hole. |
jim_hoyland Rear Rubber Bumper Top Oct 18 2020, 04:14 PM
bdstone914
The rubber top fits nicely; but it appears there ... Oct 18 2020, 04:24 PM
jim_hoyland
The rubber top fits nicely; but it appears there... Oct 18 2020, 04:30 PM
914werke :agree: If this is a back date effort you wont hav... Oct 18 2020, 04:31 PM
jim_hoyland
:agree: If this is a back date effort you wont ha... Oct 18 2020, 04:48 PM
914werke Yes it’s a backdate. It was mentioned earlier t... Oct 18 2020, 06:03 PM
Jett
Yes it’s a backdate. It was mentioned earlier ... Oct 18 2020, 08:28 PM
PanelBilly My bolt is a little long. I was going to cut it of... Oct 19 2020, 07:26 AM
Chris H. You're finally doing it eh Jim? It's gonn... Oct 19 2020, 08:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 10:35 AM |
