| Mcraneiowa |
Oct 19 2020, 06:25 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
Is it common practice to heat the little bolts holding the tin on the engiine in order to remove them. I have been soaking them with penetrating oil. Iask this is I don’t wanna get anything too hot and damage the engine case. Looking to see what others have done as I’ve already broken one I will have to tap it out just don’t wanna have to do more if I can help it
| rhodyguy |
Oct 20 2020, 02:44 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
MM (IMG:style_emoticons/default/agree.gif) . Coating, liberally, exhaust studs makes taking the nuts off a breeze next time. Repeat shots of penetrant. Be patient. If the screw head slots are shot, use vice grips and replace the screws.
Mcraneiowa Best way to remove tin bolts Oct 19 2020, 06:25 PM
porschetub
Is it common practice to heat the little bolts ho... Oct 19 2020, 06:49 PM
Gint I had one engine that was a PITA to get the tin sc... Oct 19 2020, 06:59 PM
AZBanks
I had one engine that was a PITA to get the tin s... Oct 20 2020, 01:44 AM
90quattrocoupe When you put them back in, anti-seize is your frie... Oct 20 2020, 12:38 AM
GregAmy +1 on anti-seize, and replace them with something ... Oct 20 2020, 06:34 AM
Amphicar770 When I pulled my engine I removed all of the tins ... Oct 20 2020, 09:37 AM
Dobbsy Has anyone experienced galvanic corrosion when usi... Oct 20 2020, 11:05 AM
IronHillRestorations
Has anyone experienced galvanic corrosion when us... Oct 20 2020, 11:06 AM
Dobbsy
Has anyone experienced galvanic corrosion when u... Oct 20 2020, 11:27 AM
[quote name='IronHillRestorations' post='2860414'... Oct 21 2020, 07:32 PM
73-914
Has anyone experienced galvanic corrosion when u... Oct 20 2020, 02:30 PM
Mark Henry I have a oxy/propane cutting torch, not as hot as ... Oct 20 2020, 05:02 PM
Superhawk996
I have a oxy/propane cutting torch, not as hot as... Oct 20 2020, 05:21 PM
Mark Henry
[quote name='Mark Henry' post='2860469' date='Oct... Oct 21 2020, 02:40 PM
Superhawk996
[quote name='Mark Henry' post='2860469' date='Oc... Oct 21 2020, 03:12 PM
IronHillRestorations Back on topic. I too use a hand impact when I get... Oct 21 2020, 07:58 PM
SKL1 The 914 rubber ones are nice but I guess I prefer ... Oct 21 2020, 10:43 PM
Frankvw MoM must be an American thing.....I use Ceramic Gr... Oct 22 2020, 03:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:49 AM |
