75 914 2.0 sittin along time Update! |
Slipry |
Oct 20 2020, 06:16 PM
Newbie Group: Members Posts: 20 Joined: 15-September 20 From: New Jersey Member No.: 24,693 Region Association: North East States |
Just a little update! took tank out. had alot brown sht mud in sump. all clean now Had injectors out and bench cleaned WOW! what a difference, runs great Accelerates smooth,no more Poppin/Fartin Only thing still idles at 1400 Warm no obvious vaccum leaks Where should i look first??? Thanks again guys í ½í¸Ší ¼í¿
porschetub |
Oct 20 2020, 07:41 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Just a little update! took tank out. had alot brown sht mud in sump. all clean now Had injectors out and bench cleaned WOW! what a difference, runs great Accelerates smooth,no more Poppin/Fartin Only thing still idles at 1400 Warm no obvious vaccum leaks Where should i look first??? Thanks again guys ������������ Well done getting it going,but in real terms a high idle is the sign of an air leak...keep looking pretty sure you will find some,have you tried to adjust the air fuel screw in the throttle body ?. Good luck. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:49 AM |
