> Best way to remove tin bolts, Without break8ng them
Mcraneiowa
post Oct 19 2020, 06:25 PM
Is it common practice to heat the little bolts holding the tin on the engiine in order to remove them. I have been soaking them with penetrating oil. Iask this is I don’t wanna get anything too hot and damage the engine case. Looking to see what others have done as I’ve already broken one I will have to tap it out just don’t wanna have to do more if I can help it
Mark Henry
post Oct 20 2020, 05:02 PM
that's what I do!
I have a oxy/propane cutting torch, not as hot as oxy/acetylene, but perfect for cars. For me worth the bother of an oxygen tank and propane is way cheaper than acetylene.
Superhawk996
post Oct 20 2020, 05:21 PM
QUOTE(Mark Henry @ Oct 20 2020, 07:02 PM) *
@Mark Henry
Acetylene has gotten expensive since that plant explosion back in 2018 that has constricted supply (IMG:style_emoticons/default/sad.gif)
Do you still use the same regulator(s) and tips or did you need new regulators to run propane? Do tell. I don't use much acetylene but my tank is getting low.
Even Argon has gone way up in last couple years with inflation + new Hazmat fees my gas supplier puts on bottles. (IMG:style_emoticons/default/sad.gif)
Mark Henry
post Oct 21 2020, 02:40 PM
that's what I do!
QUOTE(Superhawk996 @ Oct 20 2020, 07:21 PM) *
@Mark Henry
I just went to a welding supply shop and told them I wanted to convert, dude had me the kit in a second. IIRC the tip, sort of an inner tip and a jet.
This is 25+ years ago, 10 or so years ago I had to replace just the tip... I think?... But the welder supply had the stuff in stock.
BTW I go through lots of oxygen, but I get several years out of a tank of propane.
Superhawk996
post Oct 21 2020, 03:12 PM
QUOTE(Mark Henry @ Oct 21 2020, 04:40 PM) *
@Mark Henry
@Mark Henry
Thank you.
Mcraneiowa   Best way to remove tin bolts   Oct 19 2020, 06:25 PM
porschetub   Is it common practice to heat the little bolts ho...   Oct 19 2020, 06:49 PM
Gint   I had one engine that was a PITA to get the tin sc...   Oct 19 2020, 06:59 PM
AZBanks   I had one engine that was a PITA to get the tin s...   Oct 20 2020, 01:44 AM
90quattrocoupe   When you put them back in, anti-seize is your frie...   Oct 20 2020, 12:38 AM
GregAmy   +1 on anti-seize, and replace them with something ...   Oct 20 2020, 06:34 AM
Amphicar770   When I pulled my engine I removed all of the tins ...   Oct 20 2020, 09:37 AM
Dobbsy   Has anyone experienced galvanic corrosion when usi...   Oct 20 2020, 11:05 AM
IronHillRestorations   Has anyone experienced galvanic corrosion when us...   Oct 20 2020, 11:06 AM
Dobbsy   Has anyone experienced galvanic corrosion when u...   Oct 20 2020, 11:27 AM
IronHillRestorations   [quote name='IronHillRestorations' post='2860414'...   Oct 21 2020, 07:32 PM
73-914   Has anyone experienced galvanic corrosion when u...   Oct 20 2020, 02:30 PM
rhodyguy   MM :agree: . Coating, liberally, exhaust studs mak...   Oct 20 2020, 02:44 PM
Mark Henry   I have a oxy/propane cutting torch, not as hot as ...   Oct 20 2020, 05:02 PM
Superhawk996   I have a oxy/propane cutting torch, not as hot as...   Oct 20 2020, 05:21 PM
Mark Henry   [quote name='Mark Henry' post='2860469' date='Oct...   Oct 21 2020, 02:40 PM
Superhawk996   [quote name='Mark Henry' post='2860469' date='Oc...   Oct 21 2020, 03:12 PM
IronHillRestorations   Back on topic. I too use a hand impact when I get...   Oct 21 2020, 07:58 PM
SKL1   The 914 rubber ones are nice but I guess I prefer ...   Oct 21 2020, 10:43 PM
Frankvw   MoM must be an American thing.....I use Ceramic Gr...   Oct 22 2020, 03:04 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:41 AM
