| Mcraneiowa |
Oct 19 2020, 06:25 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
Is it common practice to heat the little bolts holding the tin on the engiine in order to remove them. I have been soaking them with penetrating oil. Iask this is I don’t wanna get anything too hot and damage the engine case. Looking to see what others have done as I’ve already broken one I will have to tap it out just don’t wanna have to do more if I can help it
| SKL1 |
Oct 21 2020, 10:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,778 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
The 914 rubber ones are nice but I guess I prefer the OEM look. Call me a purist. You can get nice new ones at McMaster Car...
Mcraneiowa Best way to remove tin bolts Oct 19 2020, 06:25 PM
porschetub
Is it common practice to heat the little bolts ho... Oct 19 2020, 06:49 PM
Gint I had one engine that was a PITA to get the tin sc... Oct 19 2020, 06:59 PM
AZBanks
I had one engine that was a PITA to get the tin s... Oct 20 2020, 01:44 AM
90quattrocoupe When you put them back in, anti-seize is your frie... Oct 20 2020, 12:38 AM
GregAmy +1 on anti-seize, and replace them with something ... Oct 20 2020, 06:34 AM
Amphicar770 When I pulled my engine I removed all of the tins ... Oct 20 2020, 09:37 AM
Dobbsy Has anyone experienced galvanic corrosion when usi... Oct 20 2020, 11:05 AM
IronHillRestorations
Has anyone experienced galvanic corrosion when us... Oct 20 2020, 11:06 AM
Dobbsy
Has anyone experienced galvanic corrosion when u... Oct 20 2020, 11:27 AM
[quote name='IronHillRestorations' post='2860414'... Oct 21 2020, 07:32 PM
73-914
Has anyone experienced galvanic corrosion when u... Oct 20 2020, 02:30 PM
rhodyguy MM :agree: . Coating, liberally, exhaust studs mak... Oct 20 2020, 02:44 PM
Mark Henry I have a oxy/propane cutting torch, not as hot as ... Oct 20 2020, 05:02 PM
Superhawk996
I have a oxy/propane cutting torch, not as hot as... Oct 20 2020, 05:21 PM
Mark Henry
[quote name='Mark Henry' post='2860469' date='Oct... Oct 21 2020, 02:40 PM
Superhawk996
[quote name='Mark Henry' post='2860469' date='Oc... Oct 21 2020, 03:12 PM
IronHillRestorations Back on topic. I too use a hand impact when I get... Oct 21 2020, 07:58 PM
Frankvw MoM must be an American thing.....I use Ceramic Gr... Oct 22 2020, 03:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:49 AM |
