Correct throttle body? - Pictures added, 73 2.0 |
Sea Rooster |
Oct 24 2020, 11:58 AM
Member Group: Members Posts: 106 Joined: 8-March 18 From: Nashville, TN Member No.: 21,948 Region Association: South East States |
Hey there,
Could you help me confirm that the throttle body I purchased for my 73 2.0 is the correct one? Here is the number and stampings I got off the part: VW LUS 039.133.067 Thanks in advance! |
JeffBowlsby |
Oct 24 2020, 10:37 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I dunno what you have. My parts book indicates PN 039.133.062B for a 74 2.0L, it’s not clear what is correct for a 1973 2.0L
JamesM |
Oct 25 2020, 02:21 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I dunno what you have. My parts book indicates PN 039.133.062B for a 74 2.0L, it’s not clear what is correct for a 1973 2.0L I believe the PET/parts books may be wrong on this one. I have seen 3 different 2.0 throttle bodies. The early style both with and without the 2nd nipple for the vac advance canister and then the later 75-76 design with the secondary spring on the throttle plate. The PET only lists the one part (039.133.062B) however if I recall (need to double check my parts stash) all of them had the same casting number (039.133.067). The "Correct" part for the 73 (early 73 at least) would be one that had no integrated return spring and had the 2nd nipple but they can be interchanged without issue. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:05 PM |
