> Just cut out on the Fwy, fuel issue
johnpierre
post Jun 23 2020, 10:25 AM
hello 914 community
so I was driving the other Sunday - nice drive with no traffic due to covid, doing 80 on the 405 heading south, for those of you that don't live in LA, that is in LA ;-) and then all of a sudden I just lost power.
it sounded like I ran out of gas but that of course is impossible as the tank was 1/2 full. I have a 73, 1.7 fuel injected engine and I have never had this issue.
I suppose I can tow the car to a garage but I thought I might put this out there in case this sounds familiar to anyone and I could try to troubleshoot the issue first. is there anything I can check rather easily to solve this? has this happened to anyone else under these conditions?
I looked all around the top of the engine as best I could when it happened and I didn't see anything disconcerted or otherwise out of place - but then again I don't really know what I was looking for and it was hot so I really could feel around that much.
-jp-
trick-e
post Oct 28 2020, 09:14 PM
Still Learning
I didn’t read all of the responses, but I’m just solving a similar issue.
Mine progressively got a little harder to start, and sometimes it wouldn’t. Now, it won’t start at all.
Confirm the pump runs when turning the key. If it does spray starter fluid into the throttle body to confirm it tries to start. If it tries, change the fuel filter first.
Next, Remove the fuel sender and/or expansion tank.
Shine a flash light into the tank.
How does the strainer look? Mine looked like someone had sealed the tank with that little mesh strainer in place. It was only a matter of time.
I’ll be pulling the tank and putting in a new strainer.
johnpierre   Just cut out on the Fwy   Jun 23 2020, 10:25 AM
BeatNavy   When you cycle the key to "on" position ...   Jun 23 2020, 10:30 AM
DRPHIL914   When you cycle the key to "on" position...   Jun 23 2020, 10:37 AM
ndfrigi   Do you have pertronix on ur dizzy? if yes try to r...   Jun 23 2020, 10:44 AM
fiacra   Despite what the gauge says did you check the tank...   Jun 23 2020, 11:00 AM
Frankvw   if the spark is OK...Check fuel (as mentioned), if...   Jun 23 2020, 11:06 AM
jd74914   I had this happen and it turned out my 3 port fue...   Jun 23 2020, 11:52 AM
KELTY360   Fuel pump relay on the relay board. I've had ...   Jun 23 2020, 02:56 PM
GregAmy   Similar experience to the above: verify solid term...   Jun 23 2020, 07:40 PM
johnpierre   hey there - thanks for all the help here is what...   Jun 23 2020, 09:40 PM
914_7T3   hey there - thanks for all the help here is wha...   Jun 23 2020, 10:53 PM
914_7T3   The dreaded double post!   Jun 23 2020, 10:53 PM
GregAmy   Given: #1 im pretty sure the fuel pump is primin...   Jun 24 2020, 09:56 AM
johnpierre   the coil presumably...   Jun 23 2020, 09:41 PM
johnpierre   vacuum hose to nowhere   Jun 23 2020, 09:42 PM
johnpierre   this is where the vac hose begins   Jun 23 2020, 09:43 PM
ndfrigi   this is where the vac hose begins that is the ...   Jun 24 2020, 01:28 AM
johnpierre   so going with a faulty fuel pump - where is it loc...   Jun 23 2020, 10:01 PM
KELTY360   Forget about the fuses. It's the fuel pump REL...   Jun 23 2020, 10:17 PM
johnpierre   Forget about the fuses. It's the fuel pump RE...   Jun 23 2020, 10:23 PM
johnpierre   ok here is the update: found the relay board - th...   Jun 24 2020, 12:31 PM
mrholland2   ok here is the update: found the relay board - t...   Jun 24 2020, 04:42 PM
johnpierre   so here is the update: fuses arrived from pelican...   Jun 25 2020, 08:26 PM
johnpierre   old relays   Jun 25 2020, 08:28 PM
johnpierre   relay board with new relays installed   Jun 25 2020, 08:29 PM
johnpierre   coil / distributor cap area - looks to be ok right...   Jun 25 2020, 08:31 PM
type2man   Remove the intake and pour fuel into the throttle ...   Jun 25 2020, 08:48 PM
johnpierre   Remove the intake and pour fuel into the throttle...   Jun 25 2020, 08:53 PM
johnpierre   Remove the intake and pour fuel into the throttle...   Jun 26 2020, 11:41 AM
rjames   This is concerning. I would check the all of the...   Jun 26 2020, 03:10 PM
johnpierre   This is concerning. I would check the all of th...   Jun 26 2020, 07:47 PM
euro911   Did you get the issue figured out yet?   Aug 16 2020, 11:38 AM
rhodyguy   Do you have spark? Easy way is hook up a timing li...   Aug 16 2020, 01:54 PM
mankowski   Intermittent loss of voltage to fuel pump could be...   Aug 17 2020, 07:33 PM
johnpierre   bump...   Oct 28 2020, 10:27 AM
johnpierre   ok everyone - it as been a few months - i just bee...   Oct 28 2020, 10:38 AM
GregAmy   I'm still not clear if your pump is consistent...   Oct 28 2020, 11:04 AM
JamesM   I'm still not clear if your pump is consisten...   Oct 28 2020, 02:14 PM
Tdskip   Rather than guessing and replacing random parts i...   Oct 28 2020, 02:29 PM
euro911   JP, there's also a couple of fuses next to eac...   Oct 28 2020, 12:54 PM
euro911   RE: Just cut out on the Fwy   Oct 28 2020, 01:16 PM
jim_hoyland   If a fuel pressure gauge is installed in-line, fue...   Oct 28 2020, 02:33 PM
euro911   I sent JP a PM, offering to run up there to help d...   Oct 28 2020, 04:20 PM
Tdskip   I sent JP a PM, offering to run up there to help ...   Oct 28 2020, 06:24 PM
trick-e   I didn’t read all of the responses, but I’m ju...   Oct 28 2020, 09:14 PM
johnpierre   ok so here is the latest with my drama: #1 as I s...   Dec 7 2020, 01:34 PM
johnpierre   :bump:   Dec 7 2020, 01:36 PM
rjames   Replacing the fuel pump might fix it, and then it ...   Dec 7 2020, 01:42 PM
johnpierre   Replacing the fuel pump might fix it, and then it...   Dec 7 2020, 02:28 PM
914Toy   Replacing the fuel pump might fix it, and then i...   Dec 7 2020, 02:41 PM
rjames   Replacing the fuel pump might fix it, and then i...   Dec 7 2020, 02:58 PM
GregAmy   Have you checked the fuel pressure yet as others ...   Dec 7 2020, 02:30 PM
rhodyguy   Was the tank sock examined? Partially fouled, they...   Dec 7 2020, 01:52 PM
sixnotfour   Has your pump been updated or still have the 3 por...   Dec 7 2020, 02:48 PM
euro911   JP, You can pick up a fairly inexpensive fuel pres...   Dec 7 2020, 04:28 PM
76-914   https://members.rennlist.com/pbanders/FPChecklist_...   Dec 7 2020, 05:37 PM
johnpierre   https://members.rennlist.com/pbanders/FPChecklist...   Dec 9 2020, 12:06 PM
euro911   Try this link, JP ... https://members.rennlist.com...   Dec 9 2020, 12:47 PM
jim_hoyland   And, I had this happen, the fuel pump ground must ...   Dec 9 2020, 07:17 PM
- Lo-Fi Version Time is now: 10th September 2026 - 12:59 PM
