alternator bench test, alternator bench test |
goobstine |
Oct 28 2020, 11:39 AM
Newbie Group: Members Posts: 30 Joined: 10-February 20 From: tucson az. Member No.: 23,908 Region Association: None |
can someone tell me where to hook my leads to bench test my alternator please ??
Spoke |
Oct 30 2020, 06:29 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
In the diagram below, the main components of the alternator are shown. There's 9 diodes, 3 stator windings, and an armature. Pretty much the only component which can be isolated is the armature. The diodes and stator windings cannot be isolated to be tested separately.
If you want to do a bench test, then you have to set up a fixture to spin the alternator while checking voltages and the current capability of the alternator. The diagram below can be used to do a bench test. Here's what you need to do to do a bench test: 1) Connect a battery between B+ on the alternator and the alternator case. 2) Do not install the voltage regulator. 3) Use the original wire harness to the voltage regulator connected to the alternator. 4) Short D+ and DF to put the alternator into maximum charge state. 5) Connect a GEN bulb as shown in the diagram. 6) Spin up the alternator to about 3k to 5k RPM; you should measure 16V at D+/DF to ground and B+ to ground. 7) The voltages between D+/DF and B+ should be within one volt of each other. This will give a good indication of alternator health. Attached thumbnail(s) |
bbrock |
Oct 30 2020, 08:32 AM
Pretty much the only component which can be isolated is the armature. The diodes and stator windings cannot be isolated to be tested separately. Assume you mean with the unit assembled. The factory manual DOES have bench testing procedures for individual components using an alternator tester but you have to have the unit opened up to do it. Thanks for that diagram! I could have used that when I rebuilt mine. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:14 PM |
