Help will not start, Debug |
neilbardsley |
Nov 8 2020, 12:39 PM
Newbie Group: Members Posts: 37 Joined: 11-October 20 From: England Member No.: 24,754 Region Association: Europe |
I've been driving around all weekend in my 914. It has never failed to start quickly. I've been giving it a tune up. Sine it's new to me. Yesterday I fitted new points and adjusted the angle from 60 to about 48. I couldn't find the timing marks so decided to wait a day.
After much searching I found the 27 degree advance mark. It's hidden on the side of the fly wheel I can't see without using my mobile. Seeing that I had moved the dwell angle from 60 to 48 I suspected the car was running a bit better because it was now too advanced. Once I took the vacuum lives off the distributor it was idling nearer 2000. After going the wrong way I figured out I needed to turn the distributor clockwise to retard it. Got it onto the timing mark when decided to attach my rpm counter to check I was at 3400 when hitting the 27 adv mark. The car stopped mid check and just refused to start again. Not clear to me what failed mid test. I suspect something electronic but ? I checked that I hadn't removed any ignition wires from the distributor cap still no luck. I should add the green oil light has stopping coming on when I try to start. Then it got dark Might order a new condenser and fit it? Anyone know the part number? Sent from my Redmi 7 using Tapatalk |
TheCabinetmaker |
Nov 9 2020, 07:05 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Also, check connections on coil, and the trigger points on the side of the diz
Lo-Fi Version | Time is now: 3rd June 2024 - 01:39 AM |
