hazzard lights on when off, off when on?, any help appreciated |
jkonzelman |
Nov 11 2020, 03:45 PM
Newbie Group: Members Posts: 21 Joined: 18-July 09 From: Athens GA Member No.: 10,578 Region Association: South East States |
(IMG:style_emoticons/default/WTF.gif)
wiring up a 1970 restoration project that I inherited totally apart. Making progress on the wiring. but the hazard lights work when the switch is pushed in (off), and they go off when pulled out (on). turn signals work, headlights work, high/low beams work, fogs work when lights in low beam mode. any suggestions? I switched out the switch with another one Ihad in a box. same issue. first impulse is the power and ground wires are wired up in reverse? |
ejm |
Nov 11 2020, 05:03 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
I would suspect that the wires to terminal 30 (constant power) and terminal 15 (switched power) are reversed.
jkonzelman |
Nov 11 2020, 05:42 PM
Lo-Fi Version | Time is now: 3rd June 2024 - 01:03 AM |
