1971 914-6 Racecar, For sale 914 6 with 1972 911T motor |
pcarfan911 |
Nov 16 2020, 10:40 PM
I'm new here ... Group: Members Posts: 0 Joined: 24-November 10 From: folsom california Member No.: 12,422 Region Association: Northern California |
$30k OBO
This was built by the previous owners of Sport Haus specifically for Reno Fernley raceway. 1971 914-6 2.4 911 T motor, 993 brakes and drilled rotors, brake cooling vents, 2 external oil coolers, 911RS exhaust, Duel 40 Webers, 901 side shift with block out plate, and race ratios (don't know what they are). Koni sport Adjustable on all 4 corners, full cage, Permatune ignition, keyless ignition, Custom upholstery and seats, completely lightened (weighs 1200 lbs, corner weighted). 3 piece centerline wheels 315 40 18 rear, 205 50 15 in the front, Prototipo Steering wheel. Has the 911 dry sump oil in the fender well, has an engine mount oil cooler from a 3.2 motor (part number told us so). We can do a compression test on request to see if internal ratios have been modified (but don't want to unnecessarily piss off the neighbors), [size=4][size=5] This car will never be street legal. VIN # 4712907848 Engine # 6129151 Type# 911/61, Crank case # 901 101 102 3R 1972 TE motor This is not an autocross car. Track car for vintage racing, or cool DE track day car for those who cannot afford GT3's. I tried it in autocross, but I could not afford the rear r-compound tires in that size. It Might do as well as the other monster 914's there if it had gumballs. Attached thumbnail(s) |
brant |
Nov 17 2020, 02:39 PM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
1200 lbs ?
Do you have a corner weight print out? |
raynekat |
Nov 18 2020, 06:06 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
1200 lbs ? Do you have a corner weight print out? Maybe 1800-1900 lbs if truly light? (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 09:23 PM |
