> Re-keying locks, Which way is easier?
aylanco
post Dec 21 2004, 10:25 PM
My car has two keys, one for the ignition and one that fits all the other locks. I would like to get it down to one key.
Right now I have both outside door handles off of the car (I'm going thru the door innards) and had a thought: Wouldn't it be easier to just take out the trunk lock and hood lock, and since I already have the door handles off, just have those all re-keyed to the ignition?
It looks like a real PITA to take off the steering column to get to the ignition switch. I had a previous experience with this on my 356 and now it's T signals don't cancel and I'm still fighting it. I just don't want to end up with two cars like that!
Thanks!
SpecialK
post Dec 22 2004, 05:54 PM
aircraft surgeon
QUOTE (aylanco @ Dec 22 2004, 02:50 PM)
QUOTE (smrz914 @ Dec 22 2004, 01:06 PM)
I would suggest using the key that is the least worn and key your locks to that key. If the key is worn then you will quickly wear out our new locks.
But I can just cut a new key to solve that. I'm just curious as to which way people would do this since my door handles are already off of the car.
Would you remove and re-key the trunk lock and hood lock, or would you remove the ignition switch instead? Which one would be easiest to do. I read the PP article on removing the ig switch and it doesn't seem to be that difficult, but if it is easier to remove the other two locks, I'd like to know.
Thanks!
If you've already got the door locks off I'd pull the two trunk locks, rekey, and be done with it. (IMHO)
- Lo-Fi Version Time is now: 9th July 2025 - 01:07 PM
