| orangecrate |
Nov 25 2020, 10:49 AM
Member ![]() ![]() Group: Members Posts: 187 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region |
Finally got the mistress to the point were I feel reasonably safe taking her on the freeway. vroom vroom Up to threw the gears to ----- no 5th !!!!! arg Back to the garage. A little reading, a linkage adjustment. Presto! 5th gear ----- and a shifter that wants to go from 1st to 4th!!! Worked fine before!!! Before you askl , all the linkage bushings are BRAND NEW. Less than a month old, slathered in antisieze. And my adjustment was only sliding the connection maybe an 1/8 of an inch ,essentially shortening it by that much.
I've owned this car 15? yrs. It was my daily for awhile before it started acting like a finicky woman. I am aware of the "vagueness" of the 914 shifter. It's a 72. Tail shifter. What am I missing here? The trans has been apart some time ago. The beginning of the frustration. My son,(a factory trained Porsche Tech) replaced a main bearing in the trans that literally fell apart. The plastic cage gave up the ghost. Could this be something he missed? It was his first teener trans. But he's not a shade tree mech like me. I really don't want to pull the trans AGAIN. I'm hoping it is some sort of adjustment thing I missed. I have rotated the shaft a spline or 2 at the connection because I was getting a lot of grinding going into 1st and that helped, as did the new bushings. ( ya think???they were trashed) . And the ball connection behind the bulkhead is new too. What am I missing???? Everything worked fine before I shortened the linkage. I had just never driven it anywhere I need 5th because of a lot of other things falling apart. Hell I've hardly driven it all for the past 10 yrs. I was elated to hit 80 with the top off again. THanks in advance for your help. |
| gereed75 |
Nov 28 2020, 09:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
I guess there could be an internal gearbox problem but it sounds like to me that you are close, just need that very last final tweak.
Keep track of where you are (mark the current position) and make very small adjustments ( one spline +/-). The correct spot is in there somewhere, just gotta find it! Good luck, be persistent |
orangecrate Phrustrated in Phoenix Nov 25 2020, 10:49 AM
orangecrate Whoever foxed my mistake in posting ,Thanks!... Nov 25 2020, 11:00 AM
brcacti if you get if fixed drive it down one hour and vi... Nov 26 2020, 08:45 AM
Amphicar770 The Tangerine precision shift kit is helpful for g... Nov 26 2020, 11:47 AM
Mikey914 If your bushings are new it REALLY tightens things... Nov 27 2020, 04:21 PM
orangecrate
If your bushings are new it REALLY tightens thing... Nov 27 2020, 10:18 PM
orangecrate
I guess there could be an internal gearbox proble... Nov 28 2020, 10:08 AM
orangecrate VICTORY. :Qarl: I had forgotten how delicate Eu... Nov 28 2020, 11:44 AM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2026 - 04:53 PM |
