Finally got the mistress to the point were I feel reasonably safe taking her on the freeway. vroom vroom Up to threw the gears to ----- no 5th !!!!! arg Back to the garage. A little reading, a linkage adjustment. Presto! 5th gear ----- and a shifter that wants to go from 1st to 4th!!! Worked fine before!!! Before you askl , all the linkage bushings are BRAND NEW. Less than a month old, slathered in antisieze. And my adjustment was only sliding the connection maybe an 1/8 of an inch ,essentially shortening it by that much.
I've owned this car 15? yrs. It was my daily for awhile before it started acting like a finicky woman. I am aware of the "vagueness" of the 914 shifter. It's a 72. Tail shifter.
What am I missing here? The trans has been apart some time ago. The beginning of the frustration. My son,(a factory trained Porsche Tech) replaced a main bearing in the trans that literally fell apart. The plastic cage gave up the ghost. Could this be something he missed? It was his first teener trans. But he's not a shade tree mech like me.
I really don't want to pull the trans AGAIN. I'm hoping it is some sort of adjustment thing I missed. I have rotated the shaft a spline or 2 at the connection because I was getting a lot of grinding going into 1st and that helped, as did the new bushings. ( ya think???they were trashed) . And the ball connection behind the bulkhead is new too. What am I missing???? Everything worked fine before I shortened the linkage. I had just never driven it anywhere I need 5th because of a lot of other things falling apart. Hell I've hardly driven it all for the past 10 yrs. I was elated to hit 80 with the top off again. THanks in advance for your help.
