> Turn key, battery goes flat, ignition switch smoky.
jaredmcginness
post Nov 30 2020, 08:25 PM
Me again.
It’s gonna be one problem post a day, until next years Octeener fest. (IMG:style_emoticons/default/idea.gif)
So close here to firing this motor (in the car)(works fine outside of it)
I’m thinking I have a short somewhere in the ignition, but everything seems to check out.
Notes:
Early car, early VW style switch. (After market)
Turn key, ACC works fine, fuel pump relay clicks, all electrics work.
12v to coil, 12v to starter, power supply relay is good.
Turn key to run, Nothing - power goes flat, as long as I hold the key down.
Messing around a bit, tried again and the ignition switch/column starts
smoking and the IGNS wires are warm.
I believe once she smokes she’s done.
I’ll buy a new switch tomorrow, but I’m trying to probe if this sounds like more than a switch.
All my wiring matches the bowlsby pages. Battery is new.
Switch was new (but probably Taiwan crap), new ground to battery and new ground strap. Cleaned every ground I can find. Does not even considering the idea of cranking.
Starter cranks fine when manually jumped.
Now that my smoke is out, queue the ‘Replacement Can’ comments. (IMG:style_emoticons/default/bye1.gif)
Spoke
post Nov 30 2020, 09:07 PM
Jerry
QUOTE(jaredmcginness @ Nov 30 2020, 09:25 PM) *
I believe there are only 3 positions for the ignition switch: Off; Running; and Start.
So when you "Turn key", this is to the Running position, correct? The 12V to the starter is measured on the large wire from the battery, correct? 12V on the large wire is constant regardless of the key position. The smaller yellow wire comes from the ignition key when in the "Start" position and puts 12V on the yellow wire to the bendix on the starter.
You mean when you go to the "Start" position, correct? In the Start position the yellow wire on the starter should be powered. This wire goes from the ignition switch to the relay board then to the starter. Try disconnecting the harness on the relay board from the cabin and see if the power goes flat.
jaredmcginness   Turn key, battery goes flat, ignition switch smoky.   Nov 30 2020, 08:25 PM
jaredmcginness   Ahh yes, found it. I’ll need to add this to my o...   Nov 30 2020, 08:49 PM
fixer34   Ahh yes, found it. I’ll need to add this to my ...   Dec 1 2020, 04:24 PM
mepstein   [quote name='jaredmcginness' post='2870837' date=...   Dec 1 2020, 05:06 PM
Spoke   Early car, early VW style switch. (After market) ...   Nov 30 2020, 09:07 PM
jaredmcginness   Correct. When I turn key to Run, I have power. Whe...   Nov 30 2020, 09:47 PM
Mikey914   Check the switch itself. There were some crappy on...   Nov 30 2020, 11:39 PM
jd74914   Check the switch itself. There were some crappy o...   Dec 1 2020, 09:46 AM
mepstein   Do you still have the switch I gave you. Does it w...   Nov 30 2020, 11:46 PM
jaredmcginness   Sound about right then Mikey, I think this was one...   Dec 1 2020, 05:15 AM
Superhawk996   I’m thinking I have a short somewhere in the i...   Dec 1 2020, 06:42 AM
jaredmcginness   the only thing that really matter is wheter or ...   Dec 1 2020, 07:48 AM
VaccaRabite   Do you have a solenoid at the starter to handle th...   Dec 1 2020, 08:56 AM
Superhawk996   As stock, all the power for starting the car goe...   Dec 1 2020, 09:19 AM
jaredmcginness   OK. Guys, as usual I step back into my question...   Dec 1 2020, 06:32 PM
FlacaProductions   I always appreciate a graceful recovery. Nice wor...   Dec 1 2020, 07:00 PM
Superhawk996   Good job finding that pinched wire! No shame ...   Dec 1 2020, 07:08 PM
Tom   Superhawk996, In the military we learned th...   Dec 3 2020, 01:43 PM
Costa05   Here is my switch I just replaced last week. Notic...   Dec 3 2020, 03:40 PM
- Lo-Fi Version Time is now: 11th September 2026 - 07:22 AM
