My name is MattR, and I have a brake problem |
MattR |
Dec 22 2004, 08:46 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Okay, so A-Aron is over here trying to help me fix my taildragger. We got the system bled, but theres not much brake pressure (none on the first pump and the second pump has minor pressure) (master cylinder (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)). There are no leaks from the bleeder valves (that we can tell), and its full of fluid in the resivoir. We bled at each corner 3 times (at least) with no bubbles left and only clear fluid remaining.
AND we just discovered my front right is stuck now too. It wasnt stuck before (before I tried to fix my brakes), but now it has pressure. WTF is wrong? Any takers? Would one bad caliper cause this? There doesnt appear to be any leaking, but maybe its seized? Or is this a master cylinder issue? Please help. I'll buy the first person that helps me a man size portion of wine and cheese (its a 912) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif). |
MXMARK |
Dec 22 2004, 08:56 PM
Member Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
I have a power bleeder that you and Aaron can borrow if you need. Sometimes the brake lines swell or break inside the line and make it so the fluid does not go to the caliper or makes it so it will lock up one of the calipers. Check the lines. If you use the power bleeder you can check the flow through the lines. Let me know. Thanks Mark
What year 912, vented front discs? |
Lo-Fi Version | Time is now: 7th June 2024 - 12:08 AM |
