| jaredmcginness |
Nov 30 2020, 08:25 PM
... ![]() ![]() ![]() Group: Members Posts: 510 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region
Me again.
It’s gonna be one problem post a day, until next years Octeener fest. (IMG:style_emoticons/default/idea.gif) So close here to firing this motor (in the car)(works fine outside of it) I’m thinking I have a short somewhere in the ignition, but everything seems to check out. Notes: Early car, early VW style switch. (After market) Turn key, ACC works fine, fuel pump relay clicks, all electrics work. 12v to coil, 12v to starter, power supply relay is good. Turn key to run, Nothing - power goes flat, as long as I hold the key down. Messing around a bit, tried again and the ignition switch/column starts smoking and the IGNS wires are warm. I believe once she smokes she’s done. I’ll buy a new switch tomorrow, but I’m trying to probe if this sounds like more than a switch. All my wiring matches the bowlsby pages. Battery is new. Switch was new (but probably Taiwan crap), new ground to battery and new ground strap. Cleaned every ground I can find. Does not even considering the idea of cranking. Starter cranks fine when manually jumped. Now that my smoke is out, queue the ‘Replacement Can’ comments. (IMG:style_emoticons/default/bye1.gif) |
| Mikey914 |
Nov 30 2020, 11:39 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Check the switch itself. There were some crappy ones made that would allow the switch to ground out and melt it.
| jd74914 |
Dec 1 2020, 09:46 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,889 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Check the switch itself. There were some crappy ones made that would allow the switch to ground out and melt it. (IMG:style_emoticons/default/agree.gif) I had this happen with 2 replacement switches before putting in a NOS. (IMG:style_emoticons/default/headbang.gif) Once while driving with the top on and windows up-couldn't believe how fast plastic smoke filled the cabin. |
jaredmcginness Turn key, battery goes flat, ignition switch smoky. Nov 30 2020, 08:25 PM
jaredmcginness Ahh yes, found it. I’ll need to add this to my o... Nov 30 2020, 08:49 PM
fixer34
Ahh yes, found it. I’ll need to add this to my ... Dec 1 2020, 04:24 PM
[quote name='jaredmcginness' post='2870837' date=... Dec 1 2020, 05:06 PM
Spoke
... Nov 30 2020, 09:07 PM
jaredmcginness Correct. When I turn key to Run, I have power. Whe... Nov 30 2020, 09:47 PM
mepstein Do you still have the switch I gave you. Does it w... Nov 30 2020, 11:46 PM
jaredmcginness Sound about right then Mikey, I think this was one... Dec 1 2020, 05:15 AM
Superhawk996
I’m thinking I have a short somewhere in the i... Dec 1 2020, 06:42 AM
jaredmcginness
the only thing that really matter is wheter or ... Dec 1 2020, 07:48 AM
VaccaRabite Do you have a solenoid at the starter to handle th... Dec 1 2020, 08:56 AM
Superhawk996
As stock, all the power for starting the car goe... Dec 1 2020, 09:19 AM
jaredmcginness OK.
Guys, as usual I step back into my question... Dec 1 2020, 06:32 PM
FlacaProductions I always appreciate a graceful recovery. Nice wor... Dec 1 2020, 07:00 PM
Superhawk996 Good job finding that pinched wire! No shame ... Dec 1 2020, 07:08 PM
Tom Superhawk996,
In the military we learned th... Dec 3 2020, 01:43 PM
Costa05 Here is my switch I just replaced last week. Notic... Dec 3 2020, 03:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th September 2026 - 07:22 AM |
