marinmcgreevy |
Member ![]() ![]() Group: Members Posts: 55 Joined: 24-June 04 From: Mill Valey, CA Member No.: 2,243 ![]() |
Hi All,
Starting to work on my 914/6. One of the things I do not like is the throttle linkage. The car has 40IDA Webers on tall manifolds. The throttle linkage is a cable (with a ball socket on the end) attached directly to the cross bar. The throttle cable goes under the engine and then makes a sharp turn up to the slot in the sheet metal for the normal 914/6 throttle rod. The car has a sideshifter so that is why I think this car is set up the way it is. The throttle works fine but having the cable make two sharp 90 degree turns does not sit well. I am looking for the bell crank that mounts on the stud that is pressed into the intake manifold. The manifold has the stud but no bell crank. Pelican carries the bushing but not the bell crank. Does anyone know of a good source for such parts? I need the bell crank and the rod that goes from the bell crank to the cross bar. I am including a photo of a set for sale on ebay. I do not need the manifold or I would bid on the parts. Thanks and Merry Christmas! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Attached image(s) ![]() |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Boy am I confused.
I thought the bellcrank (shown in your picture) mounted on the intermediate plate on the transmission. From the bellcrank (on the intermediate plate on the transmission), a solid rod extended up to the crossbar linkage between the carbs (just like a 911 setup).... The throttle cable actuates the bellcrank. Have I forgotten everything???????????? I feel very confused. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:50 PM |
