> 2.0 or more, Bigger is better
930cabman
post Nov 14 2020, 05:07 PM
I cut my wrenching teeth on VW bugs and Type 3's back in the '70's and '80's. Been somewhat out of the game for several years looking to rejoin into the 914 world. Generally the easiest way for more kick is to increase displacement. Short of going to turbo's what is available as far as big bore kits. I am not interested in going the 6 cylinder route or chevy small block route. The car will be street only, but I need speed.
VaccaRabite
post Dec 2 2020, 07:57 AM
En Garde!
you need to brace the doors or you WILL twist the chassis while welding. There are lots of threads with that information in it. But for the most part people ar building stout rods with a turnbuckle in the middle you you can dial in the right amount of load to keep the car square.
Since these cars don't have a roof to add structure welding done along the longs will put a twist in the car. And you won't notice it until the very end when you are trying to re-hang the doors and the gaps refuse to line up, or worse the door refuses to close.
Zach
930cabman
post Dec 2 2020, 11:10 AM
QUOTE(VaccaRabite @ Dec 2 2020, 08:57 AM) *
Zach
Zach,
Thank you, the reinforcing braces are at the top of my list. Back in the '80's I put a '69 Ghia back together and did not align the body at all. The car drove well for many years afterwards, but always had bad door gaps. I am considering utilizing a system that would allow test fitting the doors as progress moves along. Not sure of the method. I am considering a few spreaders at the targa area with nylon binders to hold everything together. Theoretically this would maintain the 25 1/8" number between the windshield header and the targa bar.
VaccaRabite
post Dec 3 2020, 09:48 AM
En Garde!
QUOTE(930cabman @ Dec 2 2020, 12:10 PM) *
Zach,
Don't try and bolt anything to the top of the windshield frame. Its not structural and will just bend as the car twists.
Door latch to upper door hinge, and another from the top hinge to the base of the door sill. When I say hinge, I mean make a plate that bolts into the 3 captive nuts at the top of the hinge. Again, do a search or look in the Classics section. Pics make this easier then trying to describe it.
Zach
930cabman
post Dec 3 2020, 11:22 AM
QUOTE(VaccaRabite @ Dec 3 2020, 10:48 AM) *
Zach,
Zach
Thanks for the heads up, I was hoping to have an easy way to test fit the doors as we go without removing the temporary braces.
Superhawk996
post Dec 3 2020, 12:28 PM
QUOTE(930cabman @ Dec 3 2020, 12:22 PM) *
I don't want to toot my own horn because others have done this before I did - I didn't invent this solution.
But, since I'm lazy . . . check my build thread in my signature. 1st page post #4.
My door braces don't interfere with the doors and I've done all welding with doors in place rather than try to count on measurements and trial fittings.
bbrock
post Dec 3 2020, 02:09 PM
QUOTE(Superhawk996 @ Dec 3 2020, 11:28 AM) *
Yeah, I did it too and highly recommend it. Use the upper bolt sockets for the seat belts and weld a big nut to front of the inner long near the speaker boxes. Run your adjustable brace between then ad you'll be able to install doors with the braces on.
930cabman
post Dec 3 2020, 03:21 PM
QUOTE(bbrock @ Dec 3 2020, 03:09 PM) *
Hawk, Brent,
Thanks, I have seen these in a few of the threads I have researched, just wasn't sure of the connections at the door hinge end. Can I assume it's a unanimous NO with bracing from the windshield frame?
seanpaulmc
post Dec 3 2020, 07:09 PM
QUOTE(930cabman @ Dec 3 2020, 04:21 PM) *
Hawk, Brent,
Take a look at the thread "My '74 project" by @pencap914 .
I asked the same question and he posted a very detailed shot that will be useful for you.
930cabman   2.0 or more   Nov 14 2020, 05:07 PM
Tdskip   Welcome to the forum. This is a well covered topi...   Nov 14 2020, 05:38 PM
930cabman   Welcome to the forum. This is a well covered top...   Nov 15 2020, 03:01 PM
Nogoodwithusernames   Head over to shoptalkforum and dig into the type4u...   Nov 14 2020, 08:41 PM
Bleyseng   How fast and budget? A 2056 with 120-130hp can be ...   Nov 15 2020, 04:17 PM
Cairo94507   Bleyseng just nailed it. Go with a 2056 and stock...   Nov 15 2020, 04:40 PM
930cabman   Bleyseng just nailed it. Go with a 2056 and stoc...   Nov 15 2020, 05:11 PM
Bleyseng   Bleyseng just nailed it. Go with a 2056 and sto...   Nov 15 2020, 08:46 PM
Tdskip   [quote name='930cabman' post='2866869' date='Nov ...   Nov 15 2020, 09:05 PM
Bleyseng   New 2.0L AA casting are reworked by Len with all n...   Nov 15 2020, 09:29 PM
DRPHIL914   New 2.0L AA casting are reworked by Len with all ...   Nov 15 2020, 10:03 PM
Bleyseng   New 2.0L AA casting are reworked by Len with all...   Nov 15 2020, 10:49 PM
Superhawk996   . . . AXing isn’t about acceleration but carryi...   Nov 16 2020, 07:35 AM
DRPHIL914   . . . AXing isn’t about acceleration but carry...   Nov 16 2020, 08:09 AM
VG-914   Now-a-days, you need to start keeping an eye on r...   Nov 16 2020, 08:14 AM
DRPHIL914   Now-a-days, you need to start keeping an eye on ...   Nov 16 2020, 10:49 AM
930cabman   Now-a-days, you need to start keeping an eye on...   Nov 16 2020, 01:03 PM
Bleyseng   Now-a-days, you need to start keeping an eye on ...   Nov 16 2020, 12:53 PM
914_teener   ".....I need speed...." What does this...   Nov 16 2020, 01:00 PM
Bleyseng   ".....I need speed...." Once you go...   Nov 16 2020, 02:09 PM
914_teener   ".....I need speed...." Once you g...   Nov 16 2020, 02:52 PM
Bleyseng   Yes, keep em stockish as long as its reversible th...   Nov 16 2020, 02:55 PM
930cabman   Yes, keep em stockish as long as its reversible t...   Nov 16 2020, 06:45 PM
VaccaRabite   If you have the money to build a 6 and put it in a...   Nov 17 2020, 03:02 PM
Superhawk996   If you have the money to build a 6 and put it in ...   Nov 17 2020, 03:56 PM
930cabman   If you have the money to build a 6 and put it in ...   Nov 17 2020, 05:00 PM
Bleyseng   I passed on my chance to install a six years ago w...   Nov 17 2020, 06:23 PM
Superhawk996   I passed on my chance to install a six years ago ...   Nov 17 2020, 08:20 PM
sixnotfour   I passed on my chance to install a six years ago ...   Dec 6 2020, 11:23 AM
ClayPerrine   For the cost of what I have in my 914-6 4.0, I cou...   Nov 18 2020, 03:04 PM
Bleyseng   For the cost of what I have in my 914-6 4.0, I co...   Nov 18 2020, 04:44 PM
930cabman   For the cost of what I have in my 914-6 4.0, I co...   Nov 18 2020, 04:47 PM
Bleyseng   [quote name='ClayPerrine' post='2867629' date='No...   Nov 18 2020, 07:43 PM
Tdskip   Oil tank, Wiring, front mounted engine cooler, lin...   Nov 18 2020, 09:17 PM
930cabman   Oil tank, Wiring, front mounted engine cooler, li...   Nov 19 2020, 12:04 AM
Tdskip   Oil tank, Wiring, front mounted engine cooler, l...   Nov 19 2020, 08:30 AM
bbrock   Oil tank, Wiring, front mounted engine cooler, l...   Nov 19 2020, 09:13 AM
VaccaRabite   Well that escalated quickly. :blink: Honestly...   Nov 19 2020, 10:02 AM
930cabman   Well that escalated quickly. :blink: Honestl...   Nov 20 2020, 06:39 PM
ClayPerrine   Oil tank, Wiring, front mounted engine cooler, li...   Nov 19 2020, 12:34 PM
shag   What ever you decide to do, enjoy yourself   Nov 20 2020, 09:08 PM
Bleyseng   DWD is Dirk Wrights Disease which a true story fro...   Nov 20 2020, 09:24 PM
ClayPerrine   DWD is Dirk Wrights Disease which a true story fr...   Nov 21 2020, 05:36 AM
930cabman   Thanks to all, I brought the rusted hulk home Satu...   Nov 24 2020, 05:34 PM
Tdskip   Thanks to all, I brought the rusted hulk home Sat...   Nov 25 2020, 09:33 AM
Superhawk996   Thanks to all, I brought the rusted hulk home Sat...   Nov 25 2020, 09:38 AM
930cabman   Thanks to all, I brought the rusted hulk home Sa...   Nov 25 2020, 12:49 PM
930cabman   [quote name='Superhawk996' post='2869335' date='N...   Nov 25 2020, 03:17 PM
930cabman   [quote name='930cabman' post='2869389' date='Nov ...   Nov 25 2020, 03:28 PM
914_teener   Thanks to all, I brought the rusted hulk home Sat...   Dec 2 2020, 09:32 PM
930cabman   Thanks to all, I brought the rusted hulk home Sa...   Dec 3 2020, 05:42 AM
VaccaRabite   Pics of the car! Don't even worry about a...   Nov 25 2020, 11:48 AM
Superhawk996   Whoah! You got a project on your hands. :he...   Nov 25 2020, 03:36 PM
mepstein   Sorry but that’s a parts car. :sawzall:   Nov 25 2020, 03:40 PM
Superhawk996   Sorry but that’s a parts car. :sawzall: Let...   Nov 25 2020, 04:10 PM
930cabman   Sorry but that’s a parts car. :sawzall: Let...   Nov 25 2020, 05:44 PM
bbrock   I was looking for a project, guess I found one at...   Nov 25 2020, 08:04 PM
bbrock   Looks a lot like mine did when I started my projec...   Nov 25 2020, 03:54 PM
930cabman   Yes, I found a way to get pics onto the site. Info...   Nov 26 2020, 06:32 AM
FlatSix   I'm following this thread with interest. I ha...   Nov 30 2020, 04:49 AM
930cabman   Yep, I am in for the journey now. It has been a...   Nov 30 2020, 12:14 PM
930cabman   Yep, I am in for the journey now. It has been ...   Dec 2 2020, 05:59 AM
Frankvw   wow, respect to you that you are so positive and o...   Dec 2 2020, 06:58 AM
930cabman   wow, respect to you that you are so positive and ...   Dec 2 2020, 11:04 AM
Superhawk996   :yikes: :hide: That is a project. :trophy: Ni...   Dec 2 2020, 07:29 AM
VaccaRabite   :agree: you need to brace the doors or you WILL tw...   Dec 2 2020, 07:57 AM
930cabman   :agree: you need to brace the doors or you WILL t...   Dec 2 2020, 11:10 AM
VaccaRabite   Zach, Thank you, the reinforcing braces are at...   Dec 3 2020, 09:48 AM
930cabman   Zach, Thank you, the reinforcing braces are a...   Dec 3 2020, 11:22 AM
Superhawk996   Thanks for the heads up, I was hoping to have an...   Dec 3 2020, 12:28 PM
bbrock   Thanks for the heads up, I was hoping to have a...   Dec 3 2020, 02:09 PM
930cabman   [quote name='Superhawk996' post='2871731' date='D...   Dec 3 2020, 03:21 PM
Superhawk996   Can I assume it's a unanimous NO with bracing...   Dec 3 2020, 03:49 PM
seanpaulmc   [quote name='Superhawk996' post='2871731' date='...   Dec 3 2020, 07:09 PM
930cabman   Had some progress in the shop today. I went with a...   Dec 5 2020, 03:37 PM
bbrock   We are off to the races! I think you may even...   Dec 2 2020, 09:57 PM
Frankvw   wow "Thanks for the info, I will be driving t...   Dec 3 2020, 06:01 AM
bbrock   ^^^^^^ :agree: I think bracing to the frame will...   Dec 3 2020, 05:07 PM
mepstein   I posted on PP before seeing it here but in my, no...   Dec 3 2020, 05:42 PM
930cabman   I posted on PP before seeing it here but in my, n...   Dec 3 2020, 05:59 PM
914_teener   Holy cow. You should buy that tub from that guy ...   Dec 5 2020, 09:39 PM
930cabman   Holy cow. You should buy that tub from that guy...   Dec 6 2020, 06:58 AM
Superhawk996   Holy cow. You should buy that tub from that gu...   Dec 6 2020, 07:46 AM
mepstein   [quote name='930cabman' post='2872568' date='Dec ...   Dec 6 2020, 08:03 AM
Superhawk996   I have a CA tub waiting in the wings. Bare tub ...   Dec 6 2020, 09:37 AM
mepstein   [quote name='mepstein' post='2872582' date='Dec 6...   Dec 6 2020, 10:07 AM
930cabman   [quote name='930cabman' post='2872568' date='Dec ...   Dec 6 2020, 05:12 PM
bbrock   Holy cow. You should buy that tub from that gu...   Dec 6 2020, 10:26 AM
930cabman   [quote name='930cabman' post='2872568' date='Dec ...   Dec 6 2020, 11:08 AM
Tdskip   Go Mark go!   Dec 6 2020, 10:09 AM
Superhawk996   Awesome score Mark! Look at the size of thos...   Dec 6 2020, 10:18 AM
930cabman   Found some original floor and opened up the ...   Dec 7 2020, 05:54 AM
mbseto   Wow. Mine was in a similar condition. Got the pa...   Dec 7 2020, 08:55 AM
930cabman   Wow. Mine was in a similar condition. Got the p...   Dec 7 2020, 01:38 PM
mbseto   Wow. Mine was in a similar condition. Got the ...   Dec 8 2020, 12:33 AM
pencap914   For my door brace, I found an "adjustable lin...   Dec 7 2020, 02:52 PM
pencap914   RE: 2.0 or more   Dec 7 2020, 03:00 PM
draganc   What’s the deal with us 914 guys?!?...   Dec 7 2020, 03:14 PM
930cabman   What’s the deal with us 914 guys?!?...   Dec 7 2020, 06:04 PM
VaccaRabite   Is that a "homemade" inner longitudin...   Dec 7 2020, 06:10 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 11:06 AM
