> 6 conversion throttle linkage - cable type
IronHillRestorations
post Dec 3 2020, 02:22 PM
I. I. R. C.
I've got a car in the shop that I'm finishing a 6 conversion on.
I seem to remember someone here making a cable type throttle linkage. I've used Rich Johnson's before, and have a kit here, but looking for an easier way.
Thanks in advance!
wndsrfr
post Dec 3 2020, 08:49 PM
901 Shop in Stuart, FL. No affiliation.
http://901racing.com/prod03.htm
I installed this kit on my /6 Kermee after suffering multiple failures of the $100 coat hanger due to vibration stress cracking the rod at the point it is brazed into the curved center arch. It takes the cable directly through the firewall to a new bellcrank that you install on the rotating shaft between the carbs. Their link shows the pedal end...here is the engine end....
The installation on my track/race car is typically crude, I think you could dress it up a bit in a street application.
Note that any "direct" cable linkage to the throttle control will change the dynamic response versus the OEM bellcrank system. The angle of those bellcranks allows a slight opening of the throttle plates during the initial pedal travel, then progressively more as the pedal travel continues toward WFOT...Not a big issue in racing but might be a bit bothersome in a pure street application--YMMV.
IronHillRestorations   6 conversion throttle linkage - cable type   Dec 3 2020, 02:22 PM
mepstein   Pms - Patrick Motorsport   Dec 3 2020, 02:41 PM
mb911   Pms - Patrick Motorsport :agree: I am curious...   Dec 3 2020, 04:07 PM
IronHillRestorations   I'd like to hear from someone who's got on...   Dec 3 2020, 05:07 PM
mepstein   I'd like to hear from someone who's got o...   Dec 3 2020, 05:39 PM
SirAndy   I'd like to hear from someone who's got ...   Dec 4 2020, 12:44 PM
wndsrfr   901 Shop in Stuart, FL. No affiliation. http://90...   Dec 3 2020, 08:49 PM
Mark Henry   The whole logic of the carb stock(-ish) linkage is...   Dec 4 2020, 11:37 AM
Root_Werks   The whole logic of the carb stock(-ish) linkage i...   Dec 7 2020, 11:20 AM
SirAndy   Alright, found two images, not the best detail but...   Dec 4 2020, 12:51 PM
Sway Bar   Just did a 6 conversion with Weber Carbs and REP i...   Dec 4 2020, 02:35 PM
porschetub   I see this setup in the future,plan on using a mot...   Dec 4 2020, 04:18 PM
PanelBilly   I find it easier to just call PMS. They can make i...   Dec 4 2020, 05:28 PM
IronHillRestorations   Thanks for the replies! I’ve always been a ...   Dec 5 2020, 08:38 AM
rhodyguy   Perry, Ferg mentioned having a few sets of 6 carbs...   Dec 5 2020, 12:53 PM
IronHillRestorations   Perry, Ferg mentioned having a few sets of 6 carb...   Dec 8 2020, 07:25 PM
Rose914   I've got a car in the shop that I'm finis...   Dec 6 2020, 07:46 AM
IronHillRestorations   @Ferg do you have some 3 barrel carbs to sell?   Dec 8 2020, 07:45 PM
- Lo-Fi Version Time is now: 15th April 2026 - 11:38 PM
