> Before I pull my recently installed transmission... any ideas?, SOLVED! You guys are the best.
jaredmcginness
post Dec 4 2020, 11:19 AM
Hey guys,
I posted this in my build thread, but I figured I might get some info here.
This is what is happening:
Car shifts into (I believe) every gear while the car is off. Clutch feels like it is engaging fine.
When I turn the car on, the clutch has no affect. Pretty gnarly grind sound if you move towards a gear.
The set up:
-Motor recently installed, fresh rebuild. I used my old trans, old clutch and old flywheel.
All matched originally.
-Fly wheel is true and the clutch has a lot of meat, (9.2mm, iirc)
-Clutch was never separated from the pressure plate.
-Fresh flush and trans fluid
What I've done so far:
-Read the Haynes set up, followed suit.
Chapter 5 faults calls this "Clutch Spring or Drag"
1.Too much pedal freeplay (several adjustments)
2. Splines on main shaft rusty (they are not)
3. Friction plate broken (it is not)
4. Pilot bearing worn maybe
-Adjusted cable end play. (3/4" EP, then more until it was a stiff feel.
-All new shift bushings
-Re aligned shifter. To what i THINK is in each gear. Following Dr. evils specs.
I have never driven a tail shift trans yet, so I am not used to the feel.
Any tips on anything else to check before I pull the trans and check things out inside. It was clean though, and I am pretty sure everything was aligned well and in the splines. It slid right onto the main shaft like butter.
If my throw-out bearing was too worn, I am pretty sure it would be telling me loud and clear.
Thanks! Happy Friday!
(I hope to receive the 2020 Most Questions Asked award this year (IMG:style_emoticons/default/first.gif))
914e
post Dec 4 2020, 12:19 PM
Can you crank the car over with it in gear and the clutch pushed in? You might want to disable spark, in case it would decide to start and you can't stop it.
jaredmcginness   Before I pull my recently installed transmission... any ideas?   Dec 4 2020, 11:19 AM
rgalla9146   No chance the disc got flipped ?   Dec 4 2020, 11:30 AM
wndsrfr   Tighten the cable until you can just barely depres...   Dec 4 2020, 11:39 AM
GregAmy   Tighten the cable until you can just barely depre...   Dec 4 2020, 01:34 PM
jaredmcginness   Any chance the disc got flipped ? I believe the...   Dec 4 2020, 11:39 AM
mb911   I find the cable length to be a bit long.. I would...   Dec 4 2020, 11:53 AM
mlindner   Any chance throw-out bearing is on backwards on fo...   Dec 4 2020, 11:54 AM
jaredmcginness   Here is a video of the actuation - for what it is ...   Dec 4 2020, 12:09 PM
914e   Can you crank the car over with it in gear and the...   Dec 4 2020, 12:19 PM
jaredmcginness   Can you crank the car over with it in gear and th...   Dec 4 2020, 12:25 PM
jd74914   The clutch could be stuck to the pressure plate an...   Dec 4 2020, 12:43 PM
sixnotfour   Did the clutch arm hit the trans case ?? May be a ...   Dec 4 2020, 12:48 PM
jaredmcginness   Did the clutch arm hit the trans case ?? May be a...   Dec 4 2020, 01:06 PM
mjrrti   Did the clutch arm hit the trans case ?? May be ...   Dec 4 2020, 05:06 PM
fixer34   I think the key is this statement in the original ...   Dec 4 2020, 04:21 PM
rgalla9146   I think the key is this statement in the original...   Dec 5 2020, 09:39 AM
ndfrigi   Hope just a minor fix.   Dec 4 2020, 05:15 PM
rgalla9146   Any odd noises in the tunnel when pushing the clut...   Dec 4 2020, 06:04 PM
jaredmcginness   Any odd noises in the tunnel when pushing the clu...   Dec 4 2020, 08:06 PM
rgalla9146   Any odd noises in the tunnel when pushing the cl...   Dec 4 2020, 08:56 PM
jaredmcginness   Before removing the trans remove the starter....   Dec 5 2020, 03:50 PM
rgalla9146   If you try to free the disc while driving keep the...   Dec 4 2020, 06:07 PM
iankarr   Is it possibled your clutch tube has broken free? ...   Dec 5 2020, 07:24 AM
JOEPROPER   Make sure you exhaust every possible way to diseng...   Dec 5 2020, 07:48 AM
Steve   It definitely sounds like a clutch problem. If yo...   Dec 5 2020, 11:01 AM
mlindner   Borrow a large pipe bar clamp, clamp from fork to ...   Dec 5 2020, 11:59 AM
rgalla9146   Glorious SOB is correct but credit goes to all who...   Dec 5 2020, 05:15 PM
type2man   I have had this issue a few times. Here is what I ...   Dec 5 2020, 06:43 PM
- Lo-Fi Version Time is now: 7th December 2025 - 02:08 PM
