| jaredmcginness |
Dec 4 2020, 11:19 AM
... ![]() ![]() ![]() Group: Members Posts: 509 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region
Hey guys,
I posted this in my build thread, but I figured I might get some info here. This is what is happening: Car shifts into (I believe) every gear while the car is off. Clutch feels like it is engaging fine. When I turn the car on, the clutch has no affect. Pretty gnarly grind sound if you move towards a gear. The set up: -Motor recently installed, fresh rebuild. I used my old trans, old clutch and old flywheel. All matched originally. -Fly wheel is true and the clutch has a lot of meat, (9.2mm, iirc) -Clutch was never separated from the pressure plate. -Fresh flush and trans fluid What I've done so far: -Read the Haynes set up, followed suit. Chapter 5 faults calls this "Clutch Spring or Drag" 1.Too much pedal freeplay (several adjustments) 2. Splines on main shaft rusty (they are not) 3. Friction plate broken (it is not) 4. Pilot bearing worn maybe -Adjusted cable end play. (3/4" EP, then more until it was a stiff feel. -All new shift bushings -Re aligned shifter. To what i THINK is in each gear. Following Dr. evils specs. I have never driven a tail shift trans yet, so I am not used to the feel. Any tips on anything else to check before I pull the trans and check things out inside. It was clean though, and I am pretty sure everything was aligned well and in the splines. It slid right onto the main shaft like butter. If my throw-out bearing was too worn, I am pretty sure it would be telling me loud and clear. Thanks! Happy Friday! (I hope to receive the 2020 Most Questions Asked award this year (IMG:style_emoticons/default/first.gif)) |
| fixer34 |
Dec 4 2020, 04:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,358 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
I think the key is this statement in the original post.
"Clutch was never separated from the pressure plate." If the pressure plate is removed, the clutch disc will fall out. It does not attach to the pressure plate. I think one of his pictures also showed the disc firmly 'stuck' to it. Pull the engine or trans, remove the pressure plate and separate the disc. |
jaredmcginness Before I pull my recently installed transmission... any ideas? Dec 4 2020, 11:19 AM
rgalla9146 No chance the disc got flipped ? Dec 4 2020, 11:30 AM
wndsrfr Tighten the cable until you can just barely depres... Dec 4 2020, 11:39 AM
GregAmy
Tighten the cable until you can just barely depre... Dec 4 2020, 01:34 PM
jaredmcginness
Any chance the disc got flipped ?
I believe the... Dec 4 2020, 11:39 AM
mb911 I find the cable length to be a bit long.. I would... Dec 4 2020, 11:53 AM
mlindner Any chance throw-out bearing is on backwards on fo... Dec 4 2020, 11:54 AM
jaredmcginness Here is a video of the actuation - for what it is ... Dec 4 2020, 12:09 PM
914e Can you crank the car over with it in gear and the... Dec 4 2020, 12:19 PM
jaredmcginness
Can you crank the car over with it in gear and th... Dec 4 2020, 12:25 PM
jd74914 The clutch could be stuck to the pressure plate an... Dec 4 2020, 12:43 PM
sixnotfour Did the clutch arm hit the trans case ?? May be a ... Dec 4 2020, 12:48 PM
jaredmcginness
Did the clutch arm hit the trans case ?? May be a... Dec 4 2020, 01:06 PM
mjrrti
Did the clutch arm hit the trans case ?? May be ... Dec 4 2020, 05:06 PM
rgalla9146
I think the key is this statement in the original... Dec 5 2020, 09:39 AM
ndfrigi Hope just a minor fix. Dec 4 2020, 05:15 PM
rgalla9146 Any odd noises in the tunnel when pushing the clut... Dec 4 2020, 06:04 PM
jaredmcginness
Any odd noises in the tunnel when pushing the clu... Dec 4 2020, 08:06 PM
rgalla9146
Any odd noises in the tunnel when pushing the cl... Dec 4 2020, 08:56 PM
jaredmcginness
Before removing the trans remove the starter.... Dec 5 2020, 03:50 PM
rgalla9146 If you try to free the disc while driving keep the... Dec 4 2020, 06:07 PM
iankarr Is it possibled your clutch tube has broken free? ... Dec 5 2020, 07:24 AM
JOEPROPER Make sure you exhaust every possible way to diseng... Dec 5 2020, 07:48 AM
Steve It definitely sounds like a clutch problem. If yo... Dec 5 2020, 11:01 AM
mlindner Borrow a large pipe bar clamp, clamp from fork to ... Dec 5 2020, 11:59 AM
rgalla9146 Glorious SOB is correct but credit goes to all who... Dec 5 2020, 05:15 PM
type2man I have had this issue a few times. Here is what I ... Dec 5 2020, 06:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 02:08 PM |
