| MM1 |
Dec 3 2020, 02:12 PM
914 obsession continues ![]() ![]() ![]() Group: Members Posts: 619 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California
I just purchased 2 cv axles here - described as plug and play - and when they arrived yesterday, I could hold the cv shaft and turn the cv a degree or 2 back and forth - on every cv.
Is this movement considered "worn"? When I have replaced cv axles on my Honda Odyssey (several times), I have never felt any play whatsoever on the new ones . . .in fact - the last set had worn inner cv's - dozens of techs at several dealerships failed to diagnose . . .only one service manager nailed the cause . . .still, that set had so little movement, I could not feel any . . .it just felt "more free" than the new ones. Please advise . . . |
| 76-914 |
Dec 4 2020, 11:21 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif)
| MM1 |
Dec 5 2020, 11:23 AM
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif) What's the word on cv's from PMB coming in January? How will they be different from the GKN/Loebro machined for gasket version that Eric sells now? |
| bbrock |
Dec 5 2020, 05:52 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif) What's the word on cv's from PMB coming in January? How will they be different from the GKN/Loebro machined for gasket version that Eric sells now? @Eric_Shea I'm interested in this too. I have a pair that have a bit of wear that I'd rather use than machined Type1 joints, but if there is something better, I might hold off repacking this pair that I was planning to do tomorrow. |
MM1 cv axles Dec 3 2020, 02:12 PM
IronHillRestorations Shouldn't have any rotational play Dec 3 2020, 05:10 PM
914_teener
:agree: ... Dec 3 2020, 05:52 PM
MM1 Thanks, Gents.
So don't bother cleaning/insp... Dec 3 2020, 06:29 PM
914_teener Yep...that'd be my course if I were you.
BTDT... Dec 3 2020, 07:10 PM
MM1 Sage advice - as always. Thank you, Sirs! Dec 3 2020, 07:20 PM
pete000 https://www.jbugs.com/search.html?q=cv+joint Dec 3 2020, 10:10 PM
MM1
R... Dec 4 2020, 09:31 AM
914_teener
[quote name='pete000' post='2871902' date='Dec 3 ... Dec 4 2020, 10:26 AM
MM1
[quote name='pete000' post='2871902' date='Dec 3... Dec 4 2020, 10:45 AM
bkrantz Original Porsche 914 CVs are available again. I g... Dec 3 2020, 10:12 PM
MM1
Original Porsche 914 CVs are available again. I ... Dec 4 2020, 09:10 AM
bbrock
Original Porsche 914 CVs are available again. I ... Dec 4 2020, 01:31 PM
914werke Original Porsche 914 CVs are available again. I ... Dec 4 2020, 12:06 AM
Superhawk996
Original Porsche 914 CVs are available again. I... Dec 4 2020, 10:52 AM
bkrantz
[quote name='914werke' post='2871914' date='Dec 4... Dec 4 2020, 09:04 PM
cary https://www.sunsetporscheparts.com/oem-part...int-... Dec 4 2020, 12:30 AM
pete000 Best news I have heard all day !!! Dec 4 2020, 12:50 AM
Olympic 914 I have used a glue hypo and put a small bead of RT... Dec 4 2020, 10:43 AM
914werke :agree: & those (Jbugs link) still wont work u... Dec 4 2020, 12:54 PM
MM1
:agree: & those (Jbugs link) still wont work ... Dec 4 2020, 06:41 PM
bbrock And just a little more background that I've de... Dec 4 2020, 01:38 PM
MM1
And just a little more background that I've d... Dec 4 2020, 06:44 PM
MM1 Yay! :popcorn: Dec 4 2020, 09:09 PM
bbrock Pinging @76-914 here. He's the one who firs... Dec 4 2020, 10:24 PM
Eric_Shea
[quote name='MM1' post='2872375' date='Dec 5 2020... Dec 9 2020, 10:26 AM
MM1
[quote name='MM1' post='2872375' date='Dec 5 202... Dec 9 2020, 11:32 AM
bkrantz
It's just as you stated earlier, Brock. They ... Dec 5 2020, 08:34 PM
bbrock
It's just as you stated earlier, Brock. They... Dec 5 2020, 10:37 PM
bkrantz
[quote name='bkrantz' post='2872499' date='Dec 5 ... Dec 10 2020, 09:25 PM
914werke It wouldn't matter one iota if you used 6 bo... Dec 5 2020, 02:03 AM
MM1 Is it ok to use lubro-moly cv grease for the front... Dec 7 2020, 01:54 AM
914werke :headbang: :headbang: :headbang: Dec 10 2020, 09:30 PM
bbrock What's irritating is that by this point Porsch... Dec 10 2020, 09:36 PM
MM1
What's irritating is that by this point Porsc... Dec 11 2020, 01:56 AM
Superhawk996
What's irritating is that by this point Porsc... Dec 11 2020, 07:03 AM
falcor75 Its a pity Porsche almost tripled the price on the... Dec 11 2020, 03:26 AM
ThePaintedMan Ugh... that's news to me. And ECS Tuning is th... Dec 11 2020, 08:42 AM
bbrock True, but they do seem able to understand money. ... Dec 11 2020, 08:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 07:28 PM |
