| Nacho |
Dec 5 2020, 03:54 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None
| 914_teener |
Dec 5 2020, 09:31 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Hello So I’ve been trouble shooting my Fasten Belts for a few days and not sure if I’m actually chasing a problem. With the ignition key in the off position and the key out with closed or open doors the light stays lightly dim. Thoughts? Your door switches are worn or not connected correctly assuming you have a 73 or later. |
| Nacho |
Dec 5 2020, 09:49 PM
Hello So I’ve been trouble shooting my Fasten Belts for a few days and not sure if I’m actually chasing a problem. With the ignition key in the off position and the key out with closed or open doors the light stays lightly dim. Thoughts? Your door switches are worn or not connected correctly assuming you have a 73 or later. Interesting. I have the 4 connector type door switches. Do you happen to have a picture of where the wires connect on the switches ? Thanks Nacho |
Nacho Fasten Belts light Dec 5 2020, 03:54 PM
Nacho Any wire harness gurus out there?
Nacho Dec 5 2020, 08:46 PM
914_teener
[quote name='914_teener' post='2872516' date='Dec... Dec 6 2020, 08:46 PM
Nacho
[quote name='914_teener' post='2872516' date='De... Dec 6 2020, 10:03 PM
914_7T3 @nacho
I have extra switches if you need. One o... Dec 6 2020, 07:34 PM
Nacho
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 6 2020, 09:54 PM
r_towle isn't all the seatbelt garbage wiring undernea... Dec 6 2020, 10:44 PM
mate914 I'm thinking ground issue....
If ground con... Dec 7 2020, 07:30 AM
Maltese Falcon Simple fix, set the trigger 12v signal (to the bul... Dec 7 2020, 10:24 PM
Nacho
Simple fix, set the trigger 12v signal (to the bu... Dec 9 2020, 10:22 PM
Nacho So far things are pointing at a bad drivers door s... Dec 9 2020, 10:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 02:51 PM |
