NEED 914/6 THROTTLE LINKAGE PARTS, 914/6 Throttle linkage rebuild |
marinmcgreevy |
Dec 22 2004, 06:35 PM
Member Group: Members Posts: 55 Joined: 24-June 04 From: Mill Valey, CA Member No.: 2,243 |
Hi All,
Starting to work on my 914/6. One of the things I do not like is the throttle linkage. The car has 40IDA Webers on tall manifolds. The throttle linkage is a cable (with a ball socket on the end) attached directly to the cross bar. The throttle cable goes under the engine and then makes a sharp turn up to the slot in the sheet metal for the normal 914/6 throttle rod. The car has a sideshifter so that is why I think this car is set up the way it is. The throttle works fine but having the cable make two sharp 90 degree turns does not sit well. I am looking for the bell crank that mounts on the stud that is pressed into the intake manifold. The manifold has the stud but no bell crank. Pelican carries the bushing but not the bell crank. Does anyone know of a good source for such parts? I need the bell crank and the rod that goes from the bell crank to the cross bar. I am including a photo of a set for sale on ebay. I do not need the manifold or I would bid on the parts. Thanks and Merry Christmas! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Attached image(s) |
Root_Werks |
Dec 23 2004, 10:14 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
From what you have described, sounds like you still have the 914-6 throttle cable. Pretty much everything should be a bolt-on type of deal. It may work, but making the cable turn hard corners will cause it to wear out pretty quick. I wouldn't wait. Get the parts and put it back right again.
Hey a 3.2 in your car? You gotta post some pics of it! (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 07:31 AM |
