> cv axles, -how much cv joint play is acceptable?
MM1
post Dec 3 2020, 02:12 PM
914 obsession continues
I just purchased 2 cv axles here - described as plug and play - and when they arrived yesterday, I could hold the cv shaft and turn the cv a degree or 2 back and forth - on every cv.
Is this movement considered "worn"?
When I have replaced cv axles on my Honda Odyssey (several times), I have never felt any play whatsoever on the new ones . . .in fact - the last set had worn inner cv's - dozens of techs at several dealerships failed to diagnose . . .only one service manager nailed the cause . . .still, that set had so little movement, I could not feel any . . .it just felt "more free" than the new ones.
Please advise . . .
post Dec 4 2020, 11:21 PM
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif)
MM1
post Dec 5 2020, 11:23 AM
QUOTE(76-914 @ Dec 5 2020, 12:21 AM) *
What's the word on cv's from PMB coming in January?
How will they be different from the GKN/Loebro machined for gasket version that Eric sells now?
bbrock
post Dec 5 2020, 05:52 PM
QUOTE(MM1 @ Dec 5 2020, 10:23 AM) *
@Eric_Shea
I'm interested in this too. I have a pair that have a bit of wear that I'd rather use than machined Type1 joints, but if there is something better, I might hold off repacking this pair that I was planning to do tomorrow.
Eric_Shea
post Dec 9 2020, 10:26 AM
PMB Performance
QUOTE(bbrock @ Dec 5 2020, 04:52 PM) *
@Eric_Shea
Same as we've been selling (GKN/Loebro ONLY) just having the next batch machined for the roll pins and gaskets. Exact same specs as the original. Same spline count. Same ball. Same cage. Same manufacturer. Remember... el Cheapo aftermarket stuff hyper-extends and cracks cages. Don't think you'll ever be in that situation? Ever roll out of a sharp driveway apron and lay on the gas to get into traffic? (IMG:style_emoticons/default/wink.gif)
MM1
post Dec 9 2020, 11:32 AM
QUOTE(Eric_Shea @ Dec 9 2020, 11:26 AM) *
@Eric_Shea
Thanks, Eric - I need one!
MM1   cv axles   Dec 3 2020, 02:12 PM
IronHillRestorations   Shouldn't have any rotational play   Dec 3 2020, 05:10 PM
914_teener   Shouldn't have any rotational play :agree: ...   Dec 3 2020, 05:52 PM
MM1   Thanks, Gents. So don't bother cleaning/insp...   Dec 3 2020, 06:29 PM
914_teener   Yep...that'd be my course if I were you. BTDT...   Dec 3 2020, 07:10 PM
MM1   Sage advice - as always. Thank you, Sirs!   Dec 3 2020, 07:20 PM
pete000   https://www.jbugs.com/search.html?q=cv+joint   Dec 3 2020, 10:10 PM
MM1   https://www.jbugs.com/search.html?q=cv+joint R...   Dec 4 2020, 09:31 AM
914_teener   [quote name='pete000' post='2871902' date='Dec 3 ...   Dec 4 2020, 10:26 AM
MM1   [quote name='pete000' post='2871902' date='Dec 3...   Dec 4 2020, 10:45 AM
bkrantz   Original Porsche 914 CVs are available again. I g...   Dec 3 2020, 10:12 PM
MM1   Original Porsche 914 CVs are available again. I ...   Dec 4 2020, 09:10 AM
bbrock   Original Porsche 914 CVs are available again. I ...   Dec 4 2020, 01:31 PM
914werke   Original Porsche 914 CVs are available again. I ...   Dec 4 2020, 12:06 AM
Superhawk996   Original Porsche 914 CVs are available again. I...   Dec 4 2020, 10:52 AM
bkrantz   [quote name='914werke' post='2871914' date='Dec 4...   Dec 4 2020, 09:04 PM
cary   https://www.sunsetporscheparts.com/oem-part...int-...   Dec 4 2020, 12:30 AM
pete000   Best news I have heard all day !!!   Dec 4 2020, 12:50 AM
Olympic 914   I have used a glue hypo and put a small bead of RT...   Dec 4 2020, 10:43 AM
914werke   :agree: & those (Jbugs link) still wont work u...   Dec 4 2020, 12:54 PM
MM1   :agree: & those (Jbugs link) still wont work ...   Dec 4 2020, 06:41 PM
bbrock   And just a little more background that I've de...   Dec 4 2020, 01:38 PM
MM1   And just a little more background that I've d...   Dec 4 2020, 06:44 PM
MM1   Yay! :popcorn:   Dec 4 2020, 09:09 PM
bbrock   Pinging @76-914 here. He's the one who firs...   Dec 4 2020, 10:24 PM
76-914   It's just as you stated earlier, Brock. They w...   Dec 4 2020, 11:21 PM
MM1   It's just as you stated earlier, Brock. They ...   Dec 5 2020, 11:23 AM
bbrock   It's just as you stated earlier, Brock. They...   Dec 5 2020, 05:52 PM
Eric_Shea   [quote name='MM1' post='2872375' date='Dec 5 2020...   Dec 9 2020, 10:26 AM
MM1   [quote name='MM1' post='2872375' date='Dec 5 202...   Dec 9 2020, 11:32 AM
bkrantz   It's just as you stated earlier, Brock. They ...   Dec 5 2020, 08:34 PM
bbrock   It's just as you stated earlier, Brock. They...   Dec 5 2020, 10:37 PM
bkrantz   [quote name='bkrantz' post='2872499' date='Dec 5 ...   Dec 10 2020, 09:25 PM
914werke   It wouldn't matter one iota if you used 6 bo...   Dec 5 2020, 02:03 AM
MM1   Is it ok to use lubro-moly cv grease for the front...   Dec 7 2020, 01:54 AM
914werke   :headbang: :headbang: :headbang:   Dec 10 2020, 09:30 PM
bbrock   What's irritating is that by this point Porsch...   Dec 10 2020, 09:36 PM
MM1   What's irritating is that by this point Porsc...   Dec 11 2020, 01:56 AM
Superhawk996   What's irritating is that by this point Porsc...   Dec 11 2020, 07:03 AM
falcor75   Its a pity Porsche almost tripled the price on the...   Dec 11 2020, 03:26 AM
ThePaintedMan   Ugh... that's news to me. And ECS Tuning is th...   Dec 11 2020, 08:42 AM
bbrock   True, but they do seem able to understand money. ...   Dec 11 2020, 08:43 AM
- Lo-Fi Version Time is now: 17th March 2026 - 07:23 PM
