> Coil bracket
JamesJ
post Dec 8 2020, 08:54 PM
Hello All,
I have a '74 1.8 car and I recently replaced my old black coil with a new Bosch blue coil. The new coil is a bit smaller in diameter than the black one and does not fit properly in the original coil bracket. The front side of the coil bracket is mounted with a bolt and the back side just hooks under a slot in the fan housing. I prefer not to relocate the coil bracket and have to run different lengths of wires to reach the coil in a new position. I am leaning toward an original look by having my factory coil bracket made smaller to fit the new coil, or place something between the coil and the bracket to create a tight fit that would withstand the heat from the coil but still appear original looking so as to not stand out. The car runs but is parked for now, so I just put a shop rag around the new coil temporarily until I figure out a solution that works.
What have other folks done? Any suggestions?
Thanks!
djway
post Dec 9 2020, 12:15 PM
You can also get silicone sheet in various thickness'. It last longer than most of the rubbers available.
- Lo-Fi Version Time is now: 27th November 2026 - 04:18 AM
