| JamesJ |
Dec 8 2020, 08:54 PM
Member ![]() ![]() Group: Members Posts: 300 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
Hello All,
I have a '74 1.8 car and I recently replaced my old black coil with a new Bosch blue coil. The new coil is a bit smaller in diameter than the black one and does not fit properly in the original coil bracket. The front side of the coil bracket is mounted with a bolt and the back side just hooks under a slot in the fan housing. I prefer not to relocate the coil bracket and have to run different lengths of wires to reach the coil in a new position. I am leaning toward an original look by having my factory coil bracket made smaller to fit the new coil, or place something between the coil and the bracket to create a tight fit that would withstand the heat from the coil but still appear original looking so as to not stand out. The car runs but is parked for now, so I just put a shop rag around the new coil temporarily until I figure out a solution that works. What have other folks done? Any suggestions? Thanks! Attached thumbnail(s) |
| Superhawk996 |
Dec 9 2020, 07:27 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,192 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Anybody have a part number and/or source for this style of bracket that mounts coil to the fan shroud?
I know they are on VW bus but google really hasn't turned up anything for me other aftermarket brackets that aren't the same style. I guess the probable answer is to keep an eye on Samba and/or post a WTB looking for a used one. |
| 914sgofast2 |
Dec 9 2020, 12:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Anybody have a part number and/or source for this style of bracket that mounts coil to the fan shroud? I know they are on VW bus but google really hasn't turned up anything for me other aftermarket brackets that aren't the same style. I guess the probable answer is to keep an eye on Samba and/or post a WTB looking for a used one. Those brackets were used on the VW Bay Window buses with Type 4 engines. From 1973 to 1979 I think. I have been looking for one on the Samba Want Ad site for a while. |
JamesJ Coil bracket Dec 8 2020, 08:54 PM
Mike D. I have done the same thing and used a thick piece ... Dec 8 2020, 09:02 PM
bdstone914 @jamesj
I have a roll of some 1/16 x 1 cork/rubb... Dec 8 2020, 10:16 PM
914sgofast2 Cut a section or two out of an old bicycle tube an... Dec 8 2020, 10:23 PM
JamesJ
Cut a section or two out of an old bicycle tube a... Dec 8 2020, 10:26 PM
JamesJ Thanks @Mike D. and [b]@[url=http://www.914worl... Dec 8 2020, 10:24 PM
BillC A strip of 16ga aluminum makes a great shim -- pla... Dec 9 2020, 07:48 AM
914Sixer Use the same piece of rubber that is used in the m... Dec 9 2020, 11:32 AM
rhodyguy 100%. :agree: perfect. The single outlet version f... Dec 9 2020, 12:10 PM
djway You can also get silicone sheet in various thickne... Dec 9 2020, 12:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th November 2026 - 04:18 AM |
