-6 Oil Pump Suggestions, For racing |
Jetsetsurfshop |
Dec 9 2020, 01:27 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I've been get some parts together to start assembly of my 2.7 7R case engine and the oil pump needs to be bought.
The stock one looks ok and may work perfectly fine. I just don't want a problem both oiling and have to split the case to swap pumps.(or damage expense stuff) The local Porsche dealer said the replacement pump is the 911-107-008-05. Some limited reading I can find on the web says that later pumps will fit too. Any pros and cons that anyone is aware of doing the later pumps? Thanks id advance (IMG:style_emoticons/default/beerchug.gif) |
brant |
Dec 10 2020, 01:13 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
It’s a combination of pressure and volume
Too much pressure through a front cooler causes the oil to move through the cooler too fast for maximum efficiency I had a long conversation with the engineers at fluidyne I run a brand new 3.2 pump in my 2.0/6 |
stownsen914 |
Dec 10 2020, 02:25 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Yeah that's an interesting point about flow through a cooler and the impact on cooling efficiency. I don't have a opinion on that, but from the arguments I've seen, it appears that there isn't exactly consensus on it.
More scavenging is generally considered a good thing. (Note that on 911 motors, auxiliary coolers are in the scavenge circuit.) For what it's worth, Porsche has put large pumps (with large scavenge sections) on its racecars and the later model street cars too, so there's that to consider. Meanwhile, on my 2.7 race motor, I have a standard early mag pump and always got 70-75 psi. |
Lo-Fi Version | Time is now: 4th June 2024 - 01:33 AM |
