> cv axles, -how much cv joint play is acceptable?
MM1
post Dec 3 2020, 02:12 PM
914 obsession continues
I just purchased 2 cv axles here - described as plug and play - and when they arrived yesterday, I could hold the cv shaft and turn the cv a degree or 2 back and forth - on every cv.
Is this movement considered "worn"?
When I have replaced cv axles on my Honda Odyssey (several times), I have never felt any play whatsoever on the new ones . . .in fact - the last set had worn inner cv's - dozens of techs at several dealerships failed to diagnose . . .only one service manager nailed the cause . . .still, that set had so little movement, I could not feel any . . .it just felt "more free" than the new ones.
Please advise . . .
post Dec 4 2020, 11:21 PM
It's just as you stated earlier, Brock. They won't match up to your half shafts splines if your car is a 4 banger. They're splines are for the -6 CV's. I'd get the CV's from PMB coming in January. It wouldn't matter one iota if you used 6 bolts instead of 4 bolts and 2 roll pins. (IMG:style_emoticons/default/beerchug.gif)
bkrantz
post Dec 5 2020, 08:34 PM
QUOTE(76-914 @ Dec 4 2020, 10:21 PM) *
I am still not home to confirm, but here is the listing at Pelican. They specify this CV is for the 914-4.
https://www.pelicanparts.com/More_Info/9143...&DID=168624
bbrock
post Dec 5 2020, 10:37 PM
QUOTE(bkrantz @ Dec 5 2020, 07:34 PM) *
Well that's interesting. Keeping fingers crossed for what you find. (IMG:style_emoticons/default/popcorn[1].gif)
bkrantz
post Dec 10 2020, 09:25 PM
QUOTE(bbrock @ Dec 5 2020, 09:37 PM) *
Not good news. Although the boxes are marked with 914-4 and part number 914 332 029 03 (which should be correct for 914-4) the CV inner has 25 splines, not the required 33 splines. I contacted Pelican and they are checking with the supplier (which was supposed to be Porsche). The CVs I got are GKN.
MM1   cv axles   Dec 3 2020, 02:12 PM
IronHillRestorations   Shouldn't have any rotational play   Dec 3 2020, 05:10 PM
914_teener   Shouldn't have any rotational play :agree: ...   Dec 3 2020, 05:52 PM
MM1   Thanks, Gents. So don't bother cleaning/insp...   Dec 3 2020, 06:29 PM
914_teener   Yep...that'd be my course if I were you. BTDT...   Dec 3 2020, 07:10 PM
MM1   Sage advice - as always. Thank you, Sirs!   Dec 3 2020, 07:20 PM
pete000   https://www.jbugs.com/search.html?q=cv+joint   Dec 3 2020, 10:10 PM
MM1   https://www.jbugs.com/search.html?q=cv+joint R...   Dec 4 2020, 09:31 AM
914_teener   [quote name='pete000' post='2871902' date='Dec 3 ...   Dec 4 2020, 10:26 AM
MM1   [quote name='pete000' post='2871902' date='Dec 3...   Dec 4 2020, 10:45 AM
bkrantz   Original Porsche 914 CVs are available again. I g...   Dec 3 2020, 10:12 PM
MM1   Original Porsche 914 CVs are available again. I ...   Dec 4 2020, 09:10 AM
bbrock   Original Porsche 914 CVs are available again. I ...   Dec 4 2020, 01:31 PM
914werke   Original Porsche 914 CVs are available again. I ...   Dec 4 2020, 12:06 AM
Superhawk996   Original Porsche 914 CVs are available again. I...   Dec 4 2020, 10:52 AM
bkrantz   [quote name='914werke' post='2871914' date='Dec 4...   Dec 4 2020, 09:04 PM
cary   https://www.sunsetporscheparts.com/oem-part...int-...   Dec 4 2020, 12:30 AM
pete000   Best news I have heard all day !!!   Dec 4 2020, 12:50 AM
Olympic 914   I have used a glue hypo and put a small bead of RT...   Dec 4 2020, 10:43 AM
914werke   :agree: & those (Jbugs link) still wont work u...   Dec 4 2020, 12:54 PM
MM1   :agree: & those (Jbugs link) still wont work ...   Dec 4 2020, 06:41 PM
bbrock   And just a little more background that I've de...   Dec 4 2020, 01:38 PM
MM1   And just a little more background that I've d...   Dec 4 2020, 06:44 PM
MM1   Yay! :popcorn:   Dec 4 2020, 09:09 PM
bbrock   Pinging @76-914 here. He's the one who firs...   Dec 4 2020, 10:24 PM
76-914   It's just as you stated earlier, Brock. They w...   Dec 4 2020, 11:21 PM
MM1   It's just as you stated earlier, Brock. They ...   Dec 5 2020, 11:23 AM
bbrock   It's just as you stated earlier, Brock. They...   Dec 5 2020, 05:52 PM
Eric_Shea   [quote name='MM1' post='2872375' date='Dec 5 2020...   Dec 9 2020, 10:26 AM
MM1   [quote name='MM1' post='2872375' date='Dec 5 202...   Dec 9 2020, 11:32 AM
bkrantz   It's just as you stated earlier, Brock. They ...   Dec 5 2020, 08:34 PM
bbrock   It's just as you stated earlier, Brock. They...   Dec 5 2020, 10:37 PM
bkrantz   [quote name='bkrantz' post='2872499' date='Dec 5 ...   Dec 10 2020, 09:25 PM
914werke   It wouldn't matter one iota if you used 6 bo...   Dec 5 2020, 02:03 AM
MM1   Is it ok to use lubro-moly cv grease for the front...   Dec 7 2020, 01:54 AM
914werke   :headbang: :headbang: :headbang:   Dec 10 2020, 09:30 PM
bbrock   What's irritating is that by this point Porsch...   Dec 10 2020, 09:36 PM
MM1   What's irritating is that by this point Porsc...   Dec 11 2020, 01:56 AM
Superhawk996   What's irritating is that by this point Porsc...   Dec 11 2020, 07:03 AM
falcor75   Its a pity Porsche almost tripled the price on the...   Dec 11 2020, 03:26 AM
ThePaintedMan   Ugh... that's news to me. And ECS Tuning is th...   Dec 11 2020, 08:42 AM
bbrock   True, but they do seem able to understand money. ...   Dec 11 2020, 08:43 AM
- Lo-Fi Version Time is now: 17th March 2026 - 07:25 PM
