> Checking spring position for the fan heater flaps
Mcraneiowa
post Dec 11 2020, 05:00 PM
I am reassembling the fan shroud with the heat flaps. I placed the spring underneath the hold down Tab but when working it back-and-forth it works itself up after. I moved it under the bracket against the magnesium bracket. Is that the correct position that is showing in the picture? Attached Image
Mcraneiowa
post Dec 11 2020, 05:58 PM
Thanks for the info. I had it under the tab but there is no indent in the magnesium bracket ( that the tab sit on top of) to help hold it in place and keep from working up and out when I move the flaps back and forth. Should I cut a thin line in the magnesium bracket to allow the spring wire to recess a bit which would allow the tab to lay flat and keep the wire from moving.
- Lo-Fi Version Time is now: 14th April 2026 - 09:44 AM
