-6 Oil Pump Suggestions, For racing |
Jetsetsurfshop |
Dec 9 2020, 01:27 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I've been get some parts together to start assembly of my 2.7 7R case engine and the oil pump needs to be bought.
The stock one looks ok and may work perfectly fine. I just don't want a problem both oiling and have to split the case to swap pumps.(or damage expense stuff) The local Porsche dealer said the replacement pump is the 911-107-008-05. Some limited reading I can find on the web says that later pumps will fit too. Any pros and cons that anyone is aware of doing the later pumps? Thanks id advance (IMG:style_emoticons/default/beerchug.gif) |
campbellcj |
Dec 13 2020, 09:03 AM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
My current 2.7 has a 930 or 964 P/N pump which has been working great; I'd have to look up which exact one ended up in there. Apparently a prior pump in this engine, prob the original factory one, actually had a cracked housing. Unsure if an assembly boo-boo or metallurgy/casting issue or what. I don't have that pump to inspect unfortunately.
Lo-Fi Version | Time is now: 22nd May 2024 - 09:43 PM |
