Cylinders & Pistons |
Sycolyst |
Dec 18 2020, 06:45 AM
Newbie Group: Members Posts: 42 Joined: 20-July 19 From: Northern Ohio Member No.: 23,312 Region Association: Upper MidWest |
Greetings all,
I have a 1975 2.0L motor that I'm rebuilding for my 74. The engine code is a GC. I am wanting to bump the motor to a 2056 (96x71) and have been researching cylinder and pistons kits. These kits range anywhere from $3200 to $350. My goal is to create a dependable solid running 914, not a race car or some hopped up timebomb that melts down in 10,000 miles. The engine will be fit with duel Weber 40 IDF's. Yes, I will be changing the camshaft to account for the Webers. So,....what recommendations should I consider for the purchase of these cylinders/pistons? Nickie$ (stupid money) Cast / forged Hypereutectic Biral liner Stroker JE Forged Looking for your recommendations to help me determine the best value for this build. Thanks in advance, JWB |
Montreal914 |
Dec 18 2020, 10:58 AM
Senior Member Group: Members Posts: 1,571 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
For pistons, Keith Black with Hastings rings is widely used for this setup. I have a set in my engine and have been happy. Ring gap needs to be set obviously.
Cylinders, OEM German ones bored out is definitely a nice option if you can find a place that will bore them to spec to match the KB pistons. Tolerancing issues have been reported in the past on the AA sets. You should measure every component when you rebuild anyway as a good practice. I hear Aicooled.net does a good job in checking the components they are selling but haven't bought from them. They have the AA line of product. Might be something to check with them as far as what QC is done. European Motorwerks in Hawthorn (Jorge) can help you out. He's a reputable aircooled VW shop. I got my engine block and heads reworked there and got most of my parts for my build from them. The only thing I wasn't completely pleased with were the cylinders I got from them. The spacing between the upper cooling fins is not the as the OEM ones and they are not tapered. I have no data on the effect as I am not an expert, but I will go with OEMs bored out when I open the engine again. Good luck with your build! (IMG:style_emoticons/default/smile.gif) |
930cabman |
Dec 18 2020, 06:10 PM
Advanced Member Group: Members Posts: 3,130 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
For pistons, Keith Black with Hastings rings is widely used for this setup. I have a set in my engine and have been happy. Ring gap needs to be set obviously. Cylinders, OEM German ones bored out is definitely a nice option if you can find a place that will bore them to spec to match the KB pistons. Tolerancing issues have been reported in the past on the AA sets. You should measure every component when you rebuild anyway as a good practice. I hear Aicooled.net does a good job in checking the components they are selling but haven't bought from them. They have the AA line of product. Might be something to check with them as far as what QC is done. European Motorwerks in Hawthorn (Jorge) can help you out. He's a reputable aircooled VW shop. I got my engine block and heads reworked there and got most of my parts for my build from them. The only thing I wasn't completely pleased with were the cylinders I got from them. The spacing between the upper cooling fins is not the as the OEM ones and they are not tapered. I have no data on the effect as I am not an expert, but I will go with OEMs bored out when I open the engine again. Good luck with your build! (IMG:style_emoticons/default/smile.gif) These days I am older and have a few shekels to float my hobby/illness. Cannot for the life of me can see an investment of $3+K in Nickies? Who would do this? |
Lo-Fi Version | Time is now: 1st June 2024 - 02:22 PM |
