| horizontally-opposed |
Dec 20 2020, 12:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
Plans to go for a drive in my 914 this weekend were dashed by yesterday's stay-at-home alert, so I finally dug into a minor project I've been putting off: Rebuilding the car's 28-year-old audio system. While it performed well for 15-20 years, a mixture of age, heat, moisture, etc eventually caught up to it.
System goals: 1) Install a system powerful enough to be enjoyed with the top on or off; 2) maintain/improve "period correct" appearance with no head unit and, if possible, no visible speakers; 3) minimize weight; 4) avoid or minimize additional holes/etc. I'm going into this with the understanding that it's entirely possible the exercise will be futile with a 2.2-liter flat six, but I have been collecting the parts over time and figure it's worth a shot. Some of this stuff has been sitting for years and thus may not be available anymore—but plenty of alternatives are. Old system components: Pyle graphic EQ turned on/off by factory rear defrost switch Pioneer fan-cooled amplifier (~1991) Boston Acoustics four-speaker set in doors (~1991) Pioneer ducted bass wedge in passenger footwell New system components: Smartphone with a proper mount > EQ Blaupunkt five-channel parametric EQ JL five-channel amplifier JL six-speaker set for factory speaker enclosures and door ?? subwoofer in passenger footwell (prepare for now, add later) Fair warning: This thread may proceed at a glacial pace, as midlife plus a small business means my days in the garage are fairly rare in this chapter. I'm also figuring this out as I go, and will use this thread as a journal and a place to share ideas. |
Dec 20 2020, 09:59 PM
Goals with the amp are to power the six-speaker setup while providing easy integration of a rear channel and/or a subwoofer down the road. Where the old amp was fan-cooled, this one uses traditional heat sinks.
EQ will be used mainly to accept/attenuate audio from a smartphone and to provide a remote line to turn the amp on or off, but it's nice to have the ability to adjust things. Attached thumbnail(s) |
horizontally-opposed "Invisible" audio for the Porsche 914 Dec 20 2020, 12:43 AM
horizontally-opposed Hmm, not able to upload images.
Different browse... Dec 20 2020, 12:47 AM
Jett
Hmm, not able to upload images for some reason. H... Dec 20 2020, 09:21 AM
Krieger Sometime, depending on what I'm attempting to ... Dec 20 2020, 10:58 AM
horizontally-opposed I never read the manual, either—but I was curiou... Dec 20 2020, 11:26 AM
bbrock
But, for now, this thread is…stalled. My signal... Dec 20 2020, 11:29 AM
horizontally-opposed The mids & tweeters will easily fit into the f... Dec 20 2020, 09:43 PM
BillC
The mids & tweeters will easily fit into the ... Dec 21 2020, 09:15 AM
Hopefully this is just a silly question, but hav... Dec 21 2020, 03:49 PM
horizontally-opposed On, to system components.
Goals:
1) No head uni... Dec 20 2020, 09:53 PM
bandjoey I remembered this stereo setup from some years bac... Dec 20 2020, 11:37 PM
I remembered this stereo setup from some years ba... Dec 21 2020, 12:41 AM
IronHillRestorations
I remembered this stereo setup from some years ba... Jan 11 2021, 10:29 PM
horizontally-opposed With speaker locations figured out, next up is loc... Dec 21 2020, 01:08 AM
djway The last 914 I built was like rolling around insid... Dec 21 2020, 10:33 PM
djway Well Christmas delivered me a nice 6 speaker syste... Dec 26 2020, 02:07 AM
Well Christmas delivered me a nice 6 speaker syst... Dec 26 2020, 10:52 PM
horizontally-opposed Not a huge update, but finished the rough cuts of ... Dec 26 2020, 11:03 PM
horizontally-opposed In factory enclosure, and with the speakers test f... Dec 26 2020, 11:07 PM
djway My understanding of high frequency sound waves gen... Dec 26 2020, 11:13 PM
My understanding of high frequency sound waves ge... Dec 26 2020, 11:20 PM
bbrock
My understanding of high frequency sound waves g... Dec 26 2020, 11:44 PM
BTW, I love that fancy circle cutting jig :)
... Dec 27 2020, 12:41 PM
trick-e I’ve a set of enclosed Focal tweeters, with dire... Dec 27 2020, 01:03 PM
douglastic I put a hidden system in my 68 bug .. mounted the ... Dec 27 2020, 03:38 PM
914_7T3 @horizontally-opposed
Can you share the spec on ... Jan 9 2021, 04:24 PM
Can you share the spec on the ABS plastic that y... Jan 10 2021, 03:31 PM
914_7T3
Can you share the spec on the ABS plastic that ... Jan 11 2021, 07:44 PM
windforfun I've done this in many cars. Great work! ... Jan 10 2021, 04:49 PM
IronHillRestorations Put some surface mount tweeters on either side on ... Jan 11 2021, 10:18 PM
Put some surface mount tweeters on either side on... Jan 11 2021, 11:15 PM
914forme
Also, was surprised to see JL not only recommend... Jan 13 2021, 11:46 AM
Not surprised at all with out a proper dsp you c... Jan 14 2021, 09:46 AM
horizontally-opposed Okay, back to a relatively simple but good enough ... Jan 11 2021, 11:24 PM
horizontally-opposed A bit of test fitting. May use rivets for the mids... Jan 11 2021, 11:28 PM
A bit of test fitting. May use rivets for the mid... Jan 13 2021, 11:11 AM
horizontally-opposed With the speaker enclosure plan coming into view, ... Jan 11 2021, 11:36 PM
Rob-O Those mids in the adapter plate look way too deep ... Jan 13 2021, 12:47 PM
Those mids in the adapter plate look way too deep... Jan 13 2021, 12:53 PM
914forme :agree: but I had also thought about building a sm... Jan 13 2021, 01:13 PM
Chris914n6 I had to flip your end result and mount the tweete... Jan 13 2021, 02:08 PM
I had to flip your end result and mount the tweet... Jan 14 2021, 09:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 06:35 AM |
