> Vented Rotor Stock Strut, Yes it all bolts on
djway
post Dec 29 2020, 09:32 PM
It was suggested I make this a stand alone thread so here it is. This will work for 4 or 5 lug wheels.
Parts
07,08 cayman, 05-08 boxster 2.7L (non-S) rotors.
298x24 front
299x20 rear.
Calipers 97-08 Boxster
07-08 Cayman
Adapter mount for rear caliper. Re-drilled rear hub or the soon to be released 5lug hub from URO. If you want to keep 4 lug have the Boxster rotor drilled.
Front hub that goes right onto the stock strut and can use 4 or 5 lug wheel. Front rotor mount adapter.
I have not tried but am told 15” alloy works.
Rear
Front
Once the URO rear hub is available (announced Nov 2020) this entire upgrade to Boxster brakes with 5 lug will be an off the shelf bolt on affair.
edit I believe it can be done for both early and late struts. the struts shown are late which was harder to work out.
Robarabian
post Dec 29 2020, 09:51 PM
914 A Roo
Who makes the adapter?
djway   Vented Rotor Stock Strut   Dec 29 2020, 09:32 PM
Robarabian   Who makes the adapter?   Dec 29 2020, 09:51 PM
djway   Who makes the adapter? I Worked with VDUBENGINEE...   Dec 29 2020, 10:12 PM
djway   For you early strut guys the Sebro vented rotor fo...   Dec 29 2020, 11:01 PM
Lanner   Hi guys, My name is Lanner. I built this setup. I...   Dec 30 2020, 12:18 PM
DRPHIL914   Hi guys, My name is Lanner. I built this setup. ...   Dec 30 2020, 12:56 PM
mepstein   [quote name='Lanner' post='2879113' date='Dec 30 ...   Dec 30 2020, 01:19 PM
Lanner   Dr Phil, Correct on front setup. You need the hub...   Dec 30 2020, 01:23 PM
djway   Dr Phil, Correct on front setup. You need the hu...   Dec 30 2020, 04:56 PM
Montreal914   Thank you for posting. This will get a lot of att...   Dec 30 2020, 12:25 PM
preach   Very cool!   Dec 30 2020, 12:30 PM
Lanner   Djway has been a great help, measuring things for ...   Dec 30 2020, 01:04 PM
DRPHIL914   Djway has been a great help, measuring things for...   Dec 30 2020, 01:19 PM
Lanner   Here's a VW I built on the same brake setup, 1...   Dec 30 2020, 01:29 PM
DRPHIL914   [quote name='Lanner' post='2879113' date='Dec 30...   Dec 30 2020, 01:33 PM
mepstein   [quote name='mepstein' post='2879144' date='Dec 3...   Dec 30 2020, 02:33 PM
Lanner   I agree mepstein, you are adding unsprung weight. ...   Dec 30 2020, 01:37 PM
Montreal914   Super cool bug! :) I would be curious to kn...   Dec 30 2020, 01:58 PM
Mark Henry   Super cool bug! :) I would be curious to k...   Dec 31 2020, 08:29 AM
pete000   Parking brake option...lol   Dec 30 2020, 02:28 PM
MM1   Parking brake option...lol Yep-2 of those tank...   Dec 30 2020, 02:53 PM
Lanner   @montreal914 , funny you should ask...are you in M...   Dec 30 2020, 02:32 PM
Montreal914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 30 2020, 02:42 PM
Lanner   The Boxster are 130mm radial mount. Most 911 is 89...   Dec 30 2020, 04:15 PM
djway   I found Lanner through an insane VW Fastback build...   Dec 30 2020, 04:51 PM
Lanner   @djway , the pictured calipers are just repainted ...   Jan 5 2021, 02:43 PM
ThePaintedMan   @djway [b]@[url=http://www.914world.com/bbs2/ind...   Jan 7 2021, 06:39 PM
djway   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jan 7 2021, 09:28 PM
Lanner   @ThePaintedMan . The hubs are dual pattern, so you...   Feb 17 2021, 11:01 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:57 PM
