| djway |
Dec 29 2020, 09:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
It was suggested I make this a stand alone thread so here it is. This will work for 4 or 5 lug wheels.
Parts 07,08 cayman, 05-08 boxster 2.7L (non-S) rotors. 298x24 front 299x20 rear. Calipers 97-08 Boxster 07-08 Cayman Adapter mount for rear caliper. Re-drilled rear hub or the soon to be released 5lug hub from URO. If you want to keep 4 lug have the Boxster rotor drilled. Front hub that goes right onto the stock strut and can use 4 or 5 lug wheel. Front rotor mount adapter. I have not tried but am told 15” alloy works. Rear ![]() Front ![]() Once the URO rear hub is available (announced Nov 2020) this entire upgrade to Boxster brakes with 5 lug will be an off the shelf bolt on affair. edit I believe it can be done for both early and late struts. the struts shown are late which was harder to work out. |
| Lanner |
Dec 30 2020, 01:04 PM
Newbie ![]() Group: Members Posts: 11 Joined: 30-December 20 From: Alberta Canada Member No.: 25,031 Region Association: None |
Djway has been a great help, measuring things for me and even sending me a strut to work with. I build custom brake setups for mainly the vw and Porsche 944 crowd, but I have worked on alot of different platforms. I didn't have a 914 to mockup on, so DJway sent me a spindle and has been of great help in getting this setup done.
As built, this setup has no parking brake. I could probably adapt a 911 or 944 style drum in disk setup, but would need a trailing arm to work with. Current rear setup is just a set of radial adapters for use with stock 914 rear hubs, either stock or redrilled to 5-bolt. Here is a mockup pic of the front setup. Let me know if there is something specific you'd like to see. I can build the front (hubs and brackets) for about $550. Thanks Lanner |
djway Vented Rotor Stock Strut Dec 29 2020, 09:32 PM
Robarabian Who makes the adapter? Dec 29 2020, 09:51 PM
djway
I Worked with VDUBENGINEE... Dec 29 2020, 10:12 PM
djway For you early strut guys the Sebro vented rotor fo... Dec 29 2020, 11:01 PM
Lanner Hi guys,
My name is Lanner. I built this setup. I... Dec 30 2020, 12:18 PM
DRPHIL914
Hi guys,
My name is Lanner. I built this setup. ... Dec 30 2020, 12:56 PM
[quote name='Lanner' post='2879113' date='Dec 30 ... Dec 30 2020, 01:19 PM
Lanner Dr Phil,
Correct on front setup. You need the hub... Dec 30 2020, 01:23 PM
djway
Dr Phil,
Correct on front setup. You need the hu... Dec 30 2020, 04:56 PM
Montreal914 Thank you for posting.
This will get a lot of att... Dec 30 2020, 12:25 PM
preach Very cool! Dec 30 2020, 12:30 PM
DRPHIL914
Djway has been a great help, measuring things for... Dec 30 2020, 01:19 PM
Lanner Here's a VW I built on the same brake setup, 1... Dec 30 2020, 01:29 PM
DRPHIL914
[quote name='Lanner' post='2879113' date='Dec 30... Dec 30 2020, 01:33 PM
[quote name='mepstein' post='2879144' date='Dec 3... Dec 30 2020, 02:33 PM
Lanner I agree mepstein, you are adding unsprung weight. ... Dec 30 2020, 01:37 PM
Montreal914 Super cool bug! :)
I would be curious to kn... Dec 30 2020, 01:58 PM
Mark Henry
Super cool bug! :)
I would be curious to k... Dec 31 2020, 08:29 AM
pete000 Parking brake option...lol Dec 30 2020, 02:28 PM
MM1
Yep-2 of those tank... Dec 30 2020, 02:53 PM
Lanner @montreal914 , funny you should ask...are you in M... Dec 30 2020, 02:32 PM
Montreal914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 30 2020, 02:42 PM
Lanner The Boxster are 130mm radial mount. Most 911 is 89... Dec 30 2020, 04:15 PM
djway I found Lanner through an insane VW Fastback build... Dec 30 2020, 04:51 PM
Lanner @djway , the pictured calipers are just repainted ... Jan 5 2021, 02:43 PM
ThePaintedMan @djway [b]@[url=http://www.914world.com/bbs2/ind... Jan 7 2021, 06:39 PM
djway
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jan 7 2021, 09:28 PM
Lanner @ThePaintedMan . The hubs are dual pattern, so you... Feb 17 2021, 11:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:58 PM |
