Saved From the Car Crusher!, Maybe parts should have been crushed???? |
PlantMan |
Jul 4 2014, 12:13 AM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
Hey All,
I saved this car, I am sure, from pending doom as it was sitting in a Coparts yard in the SF Bay area, not to mention it was donated to charity........ I thought it had potential so I scooped it up. My last 914 was a 1.7 (72) and I always wanted the 73-74 2.0l, so here we are. Anyways, you can see from the attached photos she is a little long in the tooth!!! BTW, this car is a true California car and appears to have spent it's entire life in NorCal. Who said Cal cars have little rust??? It also appeared to have a trans change-out around 30k miles, interesting. I have gone through 80% so far, got the car up and running, fixed a majority of the oil leaks, and now getting the brakes sorted out so I can road test it. Interior is in very good shape, minus the carpet, dashboard is a solid A grade for 40 years old and the seats and back pad are still quality as well. I am debating the AC system, which I will remove for now, but it might go back in in the future. The motor starts right-up without any problems and after I get the brakes back on I am going to check for vacuum leaks, it has a high idle but I think maybe the AAR maybe stuck. Debating the next step, starting from the front of the car and possibly working my way to the back, doing the body work. I am trying to gather pieces now for the sheet metal clean-up. Enjoy the photos! I did add it to the VIN database as well. [attachmentid=457 680] [attachmentid=457 688] Attached image(s) |
PlantMan |
Dec 30 2020, 02:23 PM
I have held on to this car for a long time!
Each time I think I am going to let it go I end up hanging on to it...... So 6 years later we are going to get into it and see what we can do over the next couple months. Engine out in a couple hours with the help from my boys and a friend in town from Texas. You have all seen this before. Lot to do in here. Injectors are rough looking but sending these out to Mr Injector. These were all working up to the time I started pulling the car apart. My son cleaning things up. Luke is no stranger to engine to working on engines. No wonder why I could not get the triple square into these. Obviously will need to replace. The clutch appears to be nearly new but the flywheel looks like garbage. Throw out bearing is clean as well. Anything to be concerned about here? Working on bracing the car today and cleaning up the engine bay. Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 04:52 PM |
