| djway |
Dec 29 2020, 09:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
It was suggested I make this a stand alone thread so here it is. This will work for 4 or 5 lug wheels.
Parts 07,08 cayman, 05-08 boxster 2.7L (non-S) rotors. 298x24 front 299x20 rear. Calipers 97-08 Boxster 07-08 Cayman Adapter mount for rear caliper. Re-drilled rear hub or the soon to be released 5lug hub from URO. If you want to keep 4 lug have the Boxster rotor drilled. Front hub that goes right onto the stock strut and can use 4 or 5 lug wheel. Front rotor mount adapter. I have not tried but am told 15” alloy works. Rear ![]() Front ![]() Once the URO rear hub is available (announced Nov 2020) this entire upgrade to Boxster brakes with 5 lug will be an off the shelf bolt on affair. edit I believe it can be done for both early and late struts. the struts shown are late which was harder to work out. |
| Lanner |
Dec 30 2020, 12:18 PM
Newbie ![]() Group: Members Posts: 11 Joined: 30-December 20 From: Alberta Canada Member No.: 25,031 Region Association: None |
Hi guys,
My name is Lanner. I built this setup. It uses new iron hubs with radial brackets for use with stock 914 spindles. Bearings and wheel seals are stock 914 and it's bolt on. It's a good option that doesn't require swapping out to 911 suspension. Please let me know if you have any questions about the setup. Thanks Lanner |
| DRPHIL914 |
Dec 30 2020, 12:56 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Hi guys, My name is Lanner. I built this setup. It uses new iron hubs with radial brackets for use with stock 914 spindles. Bearings and wheel seals are stock 914 and it's bolt on. It's a good option that doesn't require swapping out to 911 suspension. Please let me know if you have any questions about the setup. Thanks Lanner i do have a couple questions, since i have 5-lug fuchs(16") , but used the stock rotor and brakes in front with the rotor redrilled and new lugs pressed into the rotor, so currently i have all stock set up, but i do have 19mm 911 master cylinder, so my question is this: for my front if i converted over to this set up , what would i require? The boxster caliper and rotor, and the hub and spacer mounting blocks, is that it? and then source the new studs?(i want to use nuts not lug bolts) @Lanner @djway also fyi i have 914/6 5 lug hubs on rear so just using the stock caliper with stock 4 lug solid rotor drilled for 5 lug(PMB), so for rear i would just maintain my current set up , or, if i wanted the rear boxster caliper would i just get the new rotor and caliper and mount with adaptor block? seems the new rotor would just slide right on my current rear hub but new caliper with spacer would be required, OR a 914-6 or M caliper could be used too? |
| Lanner |
Dec 30 2020, 01:23 PM
Dr Phil,
Correct on front setup. You need the hubs and brackets. You can get some nice screw in studs from BMW shops or 034 motorsports. Correct on rear setup, you'd just need the radial adapters. The 914 hub will accommodate the Cayman caliper without any work. Note you lose the parking brake. I have this setup on my car (vw) with 19mm master and works well. It's been on there for over a decade. I'd suggest maybe a slightly bigger master (20.6) if you want a really tall pedal , but I've left good enough alone. On 16 fuchs the calipers need a little massaging, and maybe a slight spacer 5mm unless you have the 951 Fuchs. Pic of massaging here: In general you need 16" wheels. Some 15s fit (mainly the spare tire alloys such as 928/993 15" spare or 951 spare Thanks Lanner |
| djway |
Dec 30 2020, 04:56 PM
Dr Phil, Correct on front setup. You need the hubs and brackets. You can get some nice screw in studs from BMW shops or 034 motorsports. Correct on rear setup, you'd just need the radial adapters. The 914 hub will accommodate the Cayman caliper without any work. Note you lose the parking brake. I have this setup on my car (vw) with 19mm master and works well. It's been on there for over a decade. I'd suggest maybe a slightly bigger master (20.6) if you want a really tall pedal , but I've left good enough alone. On 16 fuchs the calipers need a little massaging, and maybe a slight spacer 5mm unless you have the 951 Fuchs. Pic of massaging here: In general you need 16" wheels. Some 15s fit (mainly the spare tire alloys such as 928/993 15" spare or 951 spare Thanks Lanner |
djway Vented Rotor Stock Strut Dec 29 2020, 09:32 PM
Robarabian Who makes the adapter? Dec 29 2020, 09:51 PM
djway
I Worked with VDUBENGINEE... Dec 29 2020, 10:12 PM
djway For you early strut guys the Sebro vented rotor fo... Dec 29 2020, 11:01 PM
[quote name='Lanner' post='2879113' date='Dec 30 ... Dec 30 2020, 01:19 PM
Montreal914 Thank you for posting.
This will get a lot of att... Dec 30 2020, 12:25 PM
preach Very cool! Dec 30 2020, 12:30 PM
Lanner Djway has been a great help, measuring things for ... Dec 30 2020, 01:04 PM
DRPHIL914
Djway has been a great help, measuring things for... Dec 30 2020, 01:19 PM
Lanner Here's a VW I built on the same brake setup, 1... Dec 30 2020, 01:29 PM
DRPHIL914
[quote name='Lanner' post='2879113' date='Dec 30... Dec 30 2020, 01:33 PM
[quote name='mepstein' post='2879144' date='Dec 3... Dec 30 2020, 02:33 PM
Lanner I agree mepstein, you are adding unsprung weight. ... Dec 30 2020, 01:37 PM
Montreal914 Super cool bug! :)
I would be curious to kn... Dec 30 2020, 01:58 PM
Mark Henry
Super cool bug! :)
I would be curious to k... Dec 31 2020, 08:29 AM
pete000 Parking brake option...lol Dec 30 2020, 02:28 PM
MM1
Yep-2 of those tank... Dec 30 2020, 02:53 PM
Lanner @montreal914 , funny you should ask...are you in M... Dec 30 2020, 02:32 PM
Montreal914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 30 2020, 02:42 PM
Lanner The Boxster are 130mm radial mount. Most 911 is 89... Dec 30 2020, 04:15 PM
djway I found Lanner through an insane VW Fastback build... Dec 30 2020, 04:51 PM
Lanner @djway , the pictured calipers are just repainted ... Jan 5 2021, 02:43 PM
ThePaintedMan @djway [b]@[url=http://www.914world.com/bbs2/ind... Jan 7 2021, 06:39 PM
djway
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jan 7 2021, 09:28 PM
Lanner @ThePaintedMan . The hubs are dual pattern, so you... Feb 17 2021, 11:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:57 PM |
