To Weld Or Not To Weld, That is the question |
Superhawk996 |
Jan 3 2021, 11:59 AM
914 Guru Group: Members Posts: 5,906 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Can't make up my mind on whether or not to weld this drain hole closed.
This drainage slot sits under the pedal cluster. I belive the intent is to let moisture from pedal area have a place to drain to. However, I will never be driving this car with snow on my boots or with shoes that would be sopping wet. Not sure this is the case though. There is no similar slot on the passenger side to drain that side. The only other thing that I can imagine this could drain is brake fluid when then Master Cylinder eventually gives up the ghost. (IMG:style_emoticons/default/confused24.gif) Rather than provide drainage, I think this slot will only serve to allow road spray and/or moisture up into the car. On new automotive sheetmetal there is no accomodation made for draining water from the footwell area. The only exception that I'm aware of are for Jeeps and the new Bronco but not likely I'll be muddin' or water fording with the 914. (IMG:style_emoticons/default/rolleyes.gif) Can anyone talk me into a reason for not welding this up? |
914_teener |
Jan 3 2021, 03:38 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I'd put a rubber plug in it as leave it as a drain unless there is another in the pan somewhere.
You never know sometimes if you will need access. Most modern cars have plugs inside the low spots in case they fill with water...beer...or coffee...or some other liquid. Besides...it's faster then welding. |
sixnotfour |
Jan 3 2021, 03:49 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I'd put a rubber plug in it as leave it as a drain unless there is another in the pan somewhere. You never know sometimes if you will need access. Most modern cars have plugs inside the low spots in case they fill with water...beer...or coffee...or some other liquid. Besides...it's faster then welding. Yup I have one Im gonna fill it with ospho..then drain it...??? |
Lo-Fi Version | Time is now: 12th June 2024 - 08:07 AM |
