> Front end upgrades
-JR-
post Dec 23 2004, 11:23 PM
Life goes faster at 150MPH
I'd like to hear from guys who have upgraded their front ends and what they chose VS what engine's they are running.
I was looking at a 935 suspension setup tonight as a possibility.
I would like to at least mount the black Brembo brakes to the car, I don't think I'll need to go as extreme as the "Big Red's" for my 3.2 car. So if anyone can suggest what cars to get suspensions from to do this I would appreciate the tips!
James
Mueller
post Dec 24 2004, 03:09 PM
914 Freak!
911 parts and options:
entire front assembly which consists of alum. crossmember, struts, a-arms and torsion bars (911 and 914 a-arms are different in that the number of splines are different so that the torsion bars are not interchangable)
or....
you can swap out just the struts, this gives you the 5 bolt hubs and bigger brake options if you go with the 3.5" caliper spacing
some 911s have an under body swaybar....the thru the body style is better and you have more options for sizes and brands
ABS came out in '89 on the 964 platform, the suspension is totally different and will not bolt on.
so stick with the years that Jeroen mentioned and you'll be okay
SmartRacing has the upper strut camber plates, they must have a "box-section" welded in, not a trival job....
(IMG:http://tcdesignfab.com/9148-3.jpg)
see V8 914 suspension mods
-JR-   Front end upgrades   Dec 23 2004, 11:23 PM
Mueller     Dec 24 2004, 12:19 AM
pete-stevers   full SC is ample bolts right in...
  Dec 24 2004, 03:05 AM
TimT   I have 911 front end, aluminum crossmember, raised...   Dec 24 2004, 03:50 AM
1973914   Tim, Some of my track buddies have given the will...   Dec 24 2004, 07:51 AM
Jeroen   get 911 SC or Carrera 3.2 struts (78 through 89) w...   Dec 24 2004, 08:02 AM
spare time toys   If you like and know the 928 set up and are going ...   Dec 24 2004, 08:04 AM
SirAndy   i got a copmplete '86 carrera frontend, as wel...   Dec 24 2004, 12:04 PM
JOHNMAN   We just went with a complete 87 911 turbo front en...   Dec 24 2004, 12:31 PM
TimT
  Dec 24 2004, 02:22 PM
-JR-     Dec 24 2004, 02:47 PM
Mueller   911 parts and options: entire front assembly whic...   Dec 24 2004, 03:09 PM
Eric_Shea   JR, I think what everyone is trying to say with r...   Dec 24 2004, 03:30 PM
Jeroen   Instead of the front camberplates pictured above (...   Dec 24 2004, 06:02 PM
TimT
  Dec 24 2004, 11:11 PM
-JR-   Mery Christmas everyone, the clock just turned ove...   Dec 25 2004, 02:37 AM
Jeroen   Yes, if you want to run coilovers, you can just ta...   Dec 25 2004, 07:45 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:40 AM
