| djway |
Dec 29 2020, 09:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
It was suggested I make this a stand alone thread so here it is. This will work for 4 or 5 lug wheels.
Parts 07,08 cayman, 05-08 boxster 2.7L (non-S) rotors. 298x24 front 299x20 rear. Calipers 97-08 Boxster 07-08 Cayman Adapter mount for rear caliper. Re-drilled rear hub or the soon to be released 5lug hub from URO. If you want to keep 4 lug have the Boxster rotor drilled. Front hub that goes right onto the stock strut and can use 4 or 5 lug wheel. Front rotor mount adapter. I have not tried but am told 15” alloy works. Rear ![]() Front ![]() Once the URO rear hub is available (announced Nov 2020) this entire upgrade to Boxster brakes with 5 lug will be an off the shelf bolt on affair. edit I believe it can be done for both early and late struts. the struts shown are late which was harder to work out. |
| ThePaintedMan |
Jan 7 2021, 06:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
@djway @Lanner - thank you guys for all of your hard work investigating this solution! I for one would definitely be interested in a front setup, but my goal would be to keep my 15" Empi-style rims. Not sure if there is a setup that would support that. The purpose for me is to increase the cooling efficiency on the front brakes by going vented. Aesthetics aren't important.
djway Vented Rotor Stock Strut Dec 29 2020, 09:32 PM
Robarabian Who makes the adapter? Dec 29 2020, 09:51 PM
djway
I Worked with VDUBENGINEE... Dec 29 2020, 10:12 PM
djway For you early strut guys the Sebro vented rotor fo... Dec 29 2020, 11:01 PM
Lanner Hi guys,
My name is Lanner. I built this setup. I... Dec 30 2020, 12:18 PM
DRPHIL914
Hi guys,
My name is Lanner. I built this setup. ... Dec 30 2020, 12:56 PM
[quote name='Lanner' post='2879113' date='Dec 30 ... Dec 30 2020, 01:19 PM
Lanner Dr Phil,
Correct on front setup. You need the hub... Dec 30 2020, 01:23 PM
djway
Dr Phil,
Correct on front setup. You need the hu... Dec 30 2020, 04:56 PM
Montreal914 Thank you for posting.
This will get a lot of att... Dec 30 2020, 12:25 PM
preach Very cool! Dec 30 2020, 12:30 PM
Lanner Djway has been a great help, measuring things for ... Dec 30 2020, 01:04 PM
DRPHIL914
Djway has been a great help, measuring things for... Dec 30 2020, 01:19 PM
Lanner Here's a VW I built on the same brake setup, 1... Dec 30 2020, 01:29 PM
DRPHIL914
[quote name='Lanner' post='2879113' date='Dec 30... Dec 30 2020, 01:33 PM
[quote name='mepstein' post='2879144' date='Dec 3... Dec 30 2020, 02:33 PM
Lanner I agree mepstein, you are adding unsprung weight. ... Dec 30 2020, 01:37 PM
Montreal914 Super cool bug! :)
I would be curious to kn... Dec 30 2020, 01:58 PM
Mark Henry
Super cool bug! :)
I would be curious to k... Dec 31 2020, 08:29 AM
pete000 Parking brake option...lol Dec 30 2020, 02:28 PM
MM1
Yep-2 of those tank... Dec 30 2020, 02:53 PM
Lanner @montreal914 , funny you should ask...are you in M... Dec 30 2020, 02:32 PM
Montreal914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 30 2020, 02:42 PM
Lanner The Boxster are 130mm radial mount. Most 911 is 89... Dec 30 2020, 04:15 PM
djway I found Lanner through an insane VW Fastback build... Dec 30 2020, 04:51 PM
Lanner @djway , the pictured calipers are just repainted ... Jan 5 2021, 02:43 PM
djway
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jan 7 2021, 09:28 PM
Lanner @ThePaintedMan . The hubs are dual pattern, so you... Feb 17 2021, 11:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:59 PM |
